HELP HUB ASSEMBLY FOR THE REAR? question - BMW Forum - BimmerWerkz.com
Old 06-02-2008, 11:54 PM   #1 (permalink)
Buckt is on a distinguished road
Hey guy i had this horrible metal to metal noise coming from the back left of my 318i so upon investigation i ruled out the brake caliper due to i took it off and went for a short drive and the noise still continued - so i am thinking its the bearings? but i am new to owning and working on bmw's could the bearings be the problem or something more sinister at play here? I lifted the car and check to see if the wheel wobbles side to side (this is what leads me to believe it is the hub assembly)and i was correct it does... but i was looking online and the rear hubs didn't look as if they were the same as front so i am confused it just didn't look like it had bearings? was i looking at the wrong parts?
Does anyone have instructions on how to change the hubs on the rear and what tools are needed?
Buckt is offline   Reply With Quote
Old 06-03-2008, 03:41 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Arrow
maybe just a loose hub locking nut? but,
chances are it's a worn bearing problem. BMW manuals say u need special tools to pull out the bearings and another special tool to install.; but i am sure you can get by if u have a hydraulic press at hand, or have access to one.
machine shops can press out and install the bearings for a nominal fee. i'd say +/- $30 wd be a fair price.
Old 06-04-2008, 11:23 AM   #3 (permalink)
na the hub is dif. gone out-
this is super complicated to do and with out manuals on how to do it- its been a tedious process so i am gonna type up with pictures how to replace the hubs and how to put it all back together because this is ridiculous - even the Chilton manual is wrong- how crazy is that?
My type up will be up here in about a day or so when i get done with my hub assembly- thanks guys!
How do you replace Rear Wheel Hub Sugarmel 5-Series (E12,E28, E34, E39, E60) 1 12-10-2005 05:02 PM
Crank Hub 85-325e 3-Series (E21, E30) 2 03-20-2005 09:12 AM
E30 Rear Brake Hub vinnie 3-Series (E21, E30) 2 02-11-2005 07:30 PM
E36 Wheel Hub To E30? E30_australia 3-Series (E21, E30) 1 02-10-2005 07:42 PM
wheel hub swap? any ideas? sand320i 3-Series (E21, E30) 1 06-03-2004 09:39 PM
