help a friend - BMW Forum - BimmerWerkz.com
Old 04-25-2007, 09:37 PM   #1 (permalink)
photoguy30523's Avatar
photoguy30523 is on a distinguished road
help a friend
ok guys i have a friend that has a 325i 87 it wont turn on, i check that it had spark and fuel well it does but it doesnt turn on, i check the injectors with a multimeter and they are not getting power?? but like i said there is fuel and spark. any ideas
photoguy30523 is offline   Reply With Quote
Old 04-25-2007, 09:39 PM   #2 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
check the fuel pump relay? fuel pump fuse?
the injectors can have all the power they want, but if fuel aint getting there you have a problem
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 04-25-2007, 09:50 PM   #3 (permalink)
there is fuel goin in the fuel regulator but at crank the injectors are not firing
Old 04-26-2007, 05:17 PM   #4 (permalink)
Car: Opening soon:
You said that the injectors are not getting power? Check it again, this time ground the negative of the tester on the motor or any metal area and test the positive on one of the pins in the plug with the key on. One pin should have 12V with the key forward.
My friend Totaled his M3... Slvr e39 Driving Tales 26 08-03-2004 02:10 AM
