help finishing a 91 318is turbo build - BMW Forum - BimmerWerkz.com
Old 09-06-2012, 03:11 PM   #1 (permalink)
Car: 88 325ix 91 325ic 91 318is turbo
bradnic is on a distinguished road
hi everyone
new to the forum. picked up a 90 318is with a partially completed budget turbo install. working on things one step at a time, but it's definitely tough to pick things up mid-stream. goal is mild boost, keep stock engine and clutch. I've picked up a limited slip for the car as well to replace the open diff it came with.
near as I can tell the engine is solid, turbo functions (mitsubishi turbo off of a miata kit). there's a massive vacuum leak somewhere which I haven't been able to chase down. when I picked the car up there was no exhaust on it, just a flex pipe attached to the turbo flange.. I had a custom exhaust system put in with 2.5" pipe, magnaflow cat and muffler. O2 sensor is installed. there is a BEGI RRFPR installed, mustang injectors, stock ECU.
there's a nasty oil leak somewhere as well - probably the return oil line on the turbo. the intercooler piping kept slipping apart, but I think I've fixed that now.
on the plus side, body and interior are in pretty decent shape after several weeks of effort, engine itself appears solid.
Looking forward to your help, advice etc as we get this beast tuned in.
91 318is AlpineWeiss Turbo 5 speed
91 325ic Calypsorot 5 speed
88 325ix Lachssilber 5 speed
bradnic is offline   Reply With Quote
Old 09-06-2012, 03:34 PM   #2 (permalink)
some pics
just registered so hope I can attach pics
help finishing a 91 318is turbo build-img_1655.jpg   help finishing a 91 318is turbo build-img_1656.jpg   help finishing a 91 318is turbo build-img_1657.jpg   help finishing a 91 318is turbo build-img_1658.jpg   help finishing a 91 318is turbo build-img_1659.jpg
Old 09-06-2012, 03:35 PM   #3 (permalink)
some more pics
more pics
help finishing a 91 318is turbo build-img_1660.jpg   help finishing a 91 318is turbo build-img_1661.jpg   help finishing a 91 318is turbo build-img_1662.jpg
Old 09-06-2012, 03:42 PM   #4 (permalink)
connected a vacuum gauge - 0 reading at closed throttle, about 15" hg when engine at 2500 rpm or so. absolutely will not idle right now, cold engine or hot.
when I got it back from the exhaust guy it was running a bit rich but not too bad. plenty of power. of course when the intercooler piping disconnected that all went to crud. everything's back together now, car was driven for about 10 miles / 20 minutes to get the ECU tuned in, heel and toeing all the way to keep it from stalling. huge cloud of black smoke as throttle closes, clearly running way rich. seems to have leaned out a bit now. also looked like some oil smoke when throttling off (like valve guides leaking oil). this is a boosted motor though so don't really think the valve guides an issue. least of my worries at this point anyway.
just want to get this thing to idle properly. we'll take it one step at a time from there.
any/all suggestions appreciated.
Old 09-06-2012, 05:18 PM   #5 (permalink)
some more info for anyone reading this:
- saw some oil seeping between the exhaust flange and the down pipe, clearly coming from the turbo bearing
- oil in the intercooler pipes all the way to the throttle body.
clearly not a good thing right? there's no scavenger pump or anything, just a line tapped into the block to the top of the turbo
Old 09-07-2012, 08:43 AM   #6 (permalink)
anyone?
any suggestions? pics of the oil leaks attached, as well as the plugs. you can see the back cylinder plug appears to be oil fouled. lotsa carbon on the other 3 which is to be expected
help finishing a 91 318is turbo build-img_1667.jpg   help finishing a 91 318is turbo build-img_1670.jpg   help finishing a 91 318is turbo build-img_1671.jpg   help finishing a 91 318is turbo build-img_1664.jpg
Old 09-07-2012, 03:24 PM   #7 (permalink)
given the lack of responses I posted a thread over at e30tech. additional info:
turbo is a mitsubishi TD04H with a 6 vane compressor wheel. don't know the compressor wheel size. one of the folks over there suggested I look into a rebuild kit given the oil leaks. the turbo has very little end play and spins freely, so no real mechanical issues to speak of. not sure how I could have bad turbo bearing seals but gonna try a rebuild to find out if that fixes things.
otherwise the next area to investigate is probably the oil feed line (maybe there's not enough restriction / too much oil being fed to turbo bearing. also gonna look at the return line. fitting in the drain pan is a bit low. fitting ID is about 1/2" but one of the folks at e30tech has a 3/4" oversized setup - in effect the large pipe is a temp reservoir for turbo oil should the oil pan port be backed up.
help finishing a 91 318is turbo build-td04h.jpg   help finishing a 91 318is turbo build-img_1676.jpg
Old 09-07-2012, 06:13 PM   #8 (permalink)
Car: 1984 325e 1995 318ti
OICU812 is on a distinguished road
m42
Hi Brad, cool project. Have you done a compression check ? Could the turbo pressurize the crankcase and cause a little blow-by. BMW has a crazy crank case ventilation system.
OICU812 is offline   Reply With Quote
Old 09-07-2012, 06:24 PM   #9 (permalink)
yeah my head's in the same place - haven't done the compression test though - trip to harbor freight in the cards...
just pulled the turbo. no oil in the exhaust manifold at all, so it's definitely the turbo's oil delivery system that's the problem. I suppose you could argue that the turbo just fried, but it appears to be mechanically sound. what I don't get is how the oil gets past the turbo bearing seals if the "mechanically sound" assessment is true.
I found a TD04H repair kit on ebay that included parts for both flatback and superback compression wheels. so I'll follow the turbo repair guide I found online.
I'm also going to take a look at the return line to make sure there's no blockage in it. if I need to I'll pull the pan and relocate the return line fitting as it's pretty obviously mounted low / below the oil line.
once this oil thing is sorted I can move on to the air/fuel mix, no idle, vacuum problem etc.
one step at a time..
Old 09-07-2012, 07:58 PM   #10 (permalink)
Rebuild kits a good ideal. That way you know the seals are good. Return line looks low but with good seals shouldn't be a problem, I'd move that last.
Old 09-07-2012, 09:02 PM   #11 (permalink)
i think the facts support your view. started to take the turbo apart by removing the clamp connecting the intake and exhaust sides.. turbine housing separated from the compressor half without any effort at all. it's pretty sloppy in there - contrary to my earlier post about no end play when I checked it while still mounted in housing and in car. then again it probably needs to rest in the turbine half to spin properly, so I may be reading too much into things.
regardless given the way it came apart, my guess is this thing's been taken apart before.
Old 09-07-2012, 09:07 PM   #12 (permalink)
picked up a nice compression gauge set with detachable hoses. will run the compression test tomorrow, but from what the PO told me I don't expect to find any issues. then again there is some oil fouling in the back cylinder (see the pic earlier in the thread showing the plugs removed)
Old 09-23-2012, 05:55 PM   #13 (permalink)
brief update
I've been updating on e30tech, but here's the skinny:
- turns out the turbo's a Greddy TD04H-15G off a miata turbo kit. there was an MHI part number on the intake side of the housing that I had missed, 49189-00640
- I ordered a rebuild kit, spent a day patiently with the CHRA getting it done
- reinstalled the turbo and refitted all the intercooler piping.
started right up. ran the car for a couple of miles, piles and piles of smoke out of the exhaust. original exhaust side turbo leak was still there. didn't check the intake side yet but I suspect the compressor side is leaking oil into the intercooler piping as well.
so bottom line turbo's probably shot. looking for a replace CHRA or turbo.
Buildy Build Build Turbo E36 M3 PrInG Forced Induction 9 11-25-2012 09:56 PM
M42 Turbo Build Frozen 318i 3-Series (E36) 176 11-19-2012 08:28 PM
Which muffler do I use for 95M3 turbo build w/3.5" from turbo back?? briangrenon2 Forced Induction 4 12-18-2009 01:56 PM
318is Turbo? daxsandman 3-Series (E21, E30) 4 10-14-2004 08:43 PM
E36 318is Turbo sabbath130 3-Series (E36) 32 10-01-2004 11:28 PM
