Help!!! Extremely Low Idle - BMW Forum - BimmerWerkz.com
Old 04-14-2009, 09:33 PM   #1 (permalink)
Car: 90' E30 M50 NV
quinescence is on a distinguished road
I don't think this has anything to do with this but i replaced my stereo. (already aftermarket wiring) previous stereo ran fine. Installed a sub woofer and 1200 wt amp. Now when i start the car it idles at 500 or lower. I drove it around the block and i get full power and acceleration. It just doesn't stop dropping rpm at 750. Radio change could just be a coincidence. ICV maybe? bad control module? I'm at a loss here. When i pulled up back to the house the idle just dropped and i started the car again and it stayed at 500 rpm
"Your not your F*c#ing khakis!"
quinescence is offline   Reply With Quote
Old 04-15-2009, 12:07 AM   #2 (permalink)
That may well be alternator drain.
Old 04-15-2009, 12:12 PM   #3 (permalink)
Car: 90' E30 M50 NV
So obvious next step would be to check the alternator for operation? Or replace? I haven't played the stereo loud yet. But i did notice the car was a little better on cold start this morning. I went to pick up some oil and by the time i got back it was running bad again
Old 04-15-2009, 12:29 PM   #4 (permalink)
That's where I'd start.
Old 04-15-2009, 08:24 PM   #5 (permalink)
Car: 90' E30 M50 NV
I changed the oil and she ran a little better still bouncing the idle just not choking at all. i checked the charge at the battery 12.56 off and 14 running. Everything is grounded to bare metal. I think it might be my tps or maybe the icv needs to be cleaned. didn't quite get to those today but tomorrow...
Old 04-16-2009, 04:43 PM   #6 (permalink)
Car: 1986 BMW 325es
M3Dreamer is on a distinguished road
Yea I had my Alpine Stereo in my car and found that it did the same thing, I had a 1000W amp with 10" subs and found that it ran a little low on idle. Since then I took out the amp and subs and it runs good. The only thing is that I have a speaker on the drivers side that fades in and out. usually helps when I hit a bump there is a loose wire somewhere. I would double check your alternator, I think autozone or some autoshops will check your alternator for free. Good luck!
"Cut your strings and be free with me!"
M3Dreamer is offline   Reply With Quote
Low Idle..O2 Sensor? topless_328 3-Series (E36) 1 12-15-2005 10:19 PM
Helpful Fix On Low Idle Fadec40 3-Series (E36) 3 04-22-2005 11:43 AM
Extremely High Idle Wont Come Down BMWjiggaB 3-Series (E36) 6 03-09-2005 06:22 AM
Low Idle Ticking locutuz 3-Series (E36) 6 11-20-2004 09:03 PM
starts then dies....very rough low idle help!! pagz 5-Series (E12,E28, E34, E39, E60) 5 07-09-2004 02:04 PM
