HELP! Engine Swap - BMW Forum - BimmerWerkz.com
post #1 of 7 (permalink) Old 06-15-2009, 09:53 AM Thread Starter
tkmw is on a distinguished road
HELP! Engine Swap
I am swapping a manual transmission motor into an auto transmission car. Motor will not connect to the bell housing. Stays about a 1/2 inch away from the bell housing. Will not mesh together. Is the crank shaft pilot bearing a different size for the auto than the manual? Cannot determine this without pulling it back out of the car. Must I just go ahead with this fate or just keep wiggling and pulling and shaking to get it in. Appreciate any help.
tkmw is offline
post #2 of 7 (permalink) Old 06-15-2009, 11:30 AM
Help from over the pond
marti5's Avatar
If its only 1/2 away, I would say its just tight going over the line up dowels as they are just over 1/2 inch, I would put some of the studs/bolts in and pull it together.
This is what I had to do when I replaced my box.
marti5 is offline
post #3 of 7 (permalink) Old 06-15-2009, 12:52 PM
romeomike's Avatar
romeomike is on a distinguished road
See if this thread helps
Different forum, but same issue with a happy ending:
WTF is the trick to mate the motor to the tranny? - Bimmerforums - The Ultimate BMW Forum
romeomike is offline
post #4 of 7 (permalink) Old 06-15-2009, 05:06 PM Thread Starter
Clarification of problem
I quess my question is I have a M20 motor that came out of a straight shift car. I am putting the motor in a car with an automatic. I replaced the fly wheel and clutch disk with the flex plate and torq converter for the automatic. I did not think to check the pilot bushing size. Are they different sizes depending on whether they are a straight shift or automatic?
tkmw is offline
post #5 of 7 (permalink) Old 06-15-2009, 07:14 PM
all I know is I did the same thing with an automatic 76 2002, swapped the engine into a 4 speed 76 2002. Needed a different flywheel and think that was it....on the 2002...I don't recall drive shaft, motor mount, electrical stuff being needed, just the flywheel assembly. Anyway, good luck
silversled is offline
post #6 of 7 (permalink) Old 06-15-2009, 07:29 PM
the only think I can think of is that you might need to re pre-load your driveshaft center bearing, that might give you the clearance....best
post #7 of 7 (permalink) Old 06-15-2009, 10:15 PM Thread Starter
Problem Found
Had to remove Pilot ball bearing from crank shaft for the torque converter to fit inside the crank. The automatic does not need the ball bearing. Repulled motor, removed ball bearing, micked crank shaft from original motor = same diameter without ball bearing on the new motor. Put motor back in and everything matched up and bolted together. Time lapse = 3 hours but it is in. Now for the odds and ends. Thanks for all the help. Hopefully this might help someone else later
tkmw is offline
v6 to v8 engine swap?? 1995bm5w 5-Series (E12,E28, E34, E39, E60) 2 07-02-2008 12:56 PM
Engine Swap seattlekid 3-Series (E21, E30) 2 08-30-2005 12:27 PM
Engine Swap? jer Bimmer Talk/Motorsports Talk 5 03-23-2005 10:05 PM
Engine Swap roundel325is 3-Series (E21, E30) 5 01-04-2005 07:25 PM
Engine Swap bimsupreme 3-Series (E21, E30) 2 11-16-2004 11:54 AM
