Help with Clutch Return Spring - BMW Forum - BimmerWerkz.com
post #1 of 6 (permalink) Old 03-15-2012, 05:00 PM Thread Starter
Stamey is an unknown quantity at this point
Question Help with Clutch Return Spring
My 1986 325 needed a new clutch master cylinder. I managed to get it replaced but now as I try to reconnect the pedal to it it looks like I am going to have a problem. The spring at the top of the pedal assembly is there, and looks OK, but when I put it in it's resting spot and press the pedal it goes "over center" and by the time the pedal gets to the floor the spring is helping to hold the pedal down. It works this way even if I have the master cylinder rod hooked to it. It didn't do this before, so I am trying to figure out what I have done wrong on re-assembly.
Without the MC connected to the pedal the pedal sits way up high due to the spring pressure but, like I said, when I push the pedal down it gets to a point where the spring starts helping to hold it down and it will not return from sitting on the floor.
I have not touched the adjustment that appears to be in the spring bolt, and the location where I am mounting the other end of the spring is what appears to be a notch in the metal, holding the spring in a horizontal position. I have tried repositioning the spring, up higher, and probably not where it's supposed to be, but that actually helps a little bit, but does not keep it from going over center when pressed down.
There is nothing in the MC as I have not replaced the slave cylinder yet. That is next.
Can anyone tell me what I did wrong, and how to fix it?
Thanks,
Chris
1997 E36, 125K
1986 E30, 323K, sold in 2014.
Other vehicles: 99 and 96 Dodge Ram 2500's, 4x4 DIESEL. Twin turbos, 600 hp and 12's in the 1/4. I wish could afford a BMW with a diesel.
Stamey is offline
post #2 of 6 (permalink) Old 03-16-2012, 03:20 PM
Captain... Savvy ?
Jack Dabsy's Avatar
Quoted: 1 Post(s)
Please post a pic of the springs' position at this time
Eso es todo!
Jack Dabsy is offline
post #3 of 6 (permalink) Old 03-16-2012, 04:04 PM Thread Starter
OK, I'm trying here, but it is difficult to get a good pic and see what's going on because it's tight and hard to get a good angle.
At least one shows the pedal all the way on the floor.
I can try to get other angles if you tell me what you need.
Thanks,
Chris
ID:	29995   Click image for larger version
ID:	29996   Click image for larger version
1997 E36, 125K
Stamey is offline
post #4 of 6 (permalink) Old 03-16-2012, 07:01 PM Thread Starter
OK, I found where the over-center clutch assist spring is mentioned in the bmw_e30_repair_manual_v7.pdf (page 365) in the sticky in the forum. It doesn't say much except that it is an over-center spring and needs to be in the notch, which I did. I guess what keeps it from staying on the floor is the push of the fluid from the clutch springs.
Chris
1997 E36, 125K
Stamey is offline
post #5 of 6 (permalink) Old 03-17-2012, 05:34 AM
Captain... Savvy ?
Jack Dabsy's Avatar
Quoted: 1 Post(s)
Also noticed a small damper disconnected...
Eso es todo!
post #6 of 6 (permalink) Old 03-17-2012, 01:53 PM Thread Starter
Well installed as per the manual, it it appears that the pressure from the clutch keeps pushes it enough to tip it back over the center, and it works just fine now.
What damper are you speaking of?
Thanks for the help.
Chris
1997 E36, 125K
Stamey is offline
Clutch Return Stop? Gkamysz 3-Series (E36) 0 05-31-2005 12:28 PM
Finally...tax Return Is Here!!! jbnery6465 3-Series (E36) 7 05-12-2005 09:20 AM
Clutch Return Spring Andrewsd1985 3-Series (E36) 1 11-26-2003 11:18 PM
