Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 07-26-2007, 06:42 PM   #1 (permalink)
Rfitz25's Avatar
Photos: 0
Rfitz25 is on a distinguished road
Question Help: Aux fan magna resistor, What is the resistance?
I have the magna style not the Bosch style.
Anyone know what the resistance rating is supposed to be so I can replace it cheap not the $40 replacement?
I read a post once from someone that did this and it worked fine.
I think I can get the right aluminum cased spun resistor part cheap, I just need to know the ohms needed.
I'm going to be replacing the brocken fan with a used one and want to throw in a new risistor while I'm at it.
Summer heat!! San Diego.
Thanks in advance
StarMavin??
Cheers,
Richard Fitz
'87 325is Delphin Metalic
Rfitz25 is offline   Reply With Quote
Old 07-27-2007, 09:02 AM   #2 (permalink)
Car: Opening soon:
Photos: 0
I can't seem to find any values on the magna style. The magna and the bosch don't interchange so the bosch values won't help you.
Old 07-30-2007, 12:56 AM   #3 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Photos: 5
Get one from Pick-n-Pull or don't go out to dinner a few times and just buy a new one.
My M50 Powered E30 Page
Old 07-31-2007, 04:31 PM   #4 (permalink)
Rfitz25's Avatar
Photos: 0
Are the Bosh and Magna style different ratings or just different wiring connectors?
Whats the Bosch rating anyway if you have it handy?
I believe my existing one is still good I just wanted to put a new resistor in when I replace the fan with a clean used fan, which I havent found yet.
I can get a nice clean aluminum cased finned resistor cheap that should do the job.
Cheers,
Richard Fitz
Old 07-31-2007, 09:20 PM   #5 (permalink)
Car: Opening soon:
Photos: 0
The bosch is around .3 to .5 ohms at 85 watts. The bosch uses a resistor wire where as the magna brand uses a magnetic style ballast resistor. Often times the glue lets the magnets loosen up and fall out of place then it can't transfer the volts. They "can" be fixed but more times than not you'll end up destroying it trying to get it open.
Old 08-12-2007, 04:35 PM   #6 (permalink)
Rfitz25's Avatar
Photos: 0
Bump LOL
Questions:
It was payday fri so I'm close to going to the boneyard for a used aux fan.
However:
I spin the main cooling fan when its hot and it still spins freely??? Is is bad??? Looks good no oil leak? Shouldnt the fan clutch kick in when its hot and be hard to spin? (of course I do this without motor running)
Maybe I'll do the clutch at the same time as aux fan but hate to replace good parts?
In the mean time I'll race my virtual BMW M3 GTR on Forza motorsports Live LOL
as well as my BMW V12 LMR and McLaren F1 BMW
Cheers,
Richard Fitz
Old 08-12-2007, 09:53 PM   #7 (permalink)
Car: Opening soon:
Photos: 0
Sounds like the fan clutch is shot.
Old 08-15-2007, 01:46 PM   #8 (permalink)
Rfitz25's Avatar
Photos: 0
Not so sure now.
I did the magazine/newspaper fan clutch test when I got home last night, it was all warmed up, I used a good cardboard paper towel tube (read in some other posts) and tried really hard but I couldnt stop the fan. Seems like the clutch was well engaged.
Maybe it only fails at really high temp like at the last autox.
Found a new aux fan at local inter auto parts $185 but its the bosch ceramic resistor and fan blades arent attached to the outer ring like mine is and the wire conneector is much shorter so I'm not going to buy it? The pic from bavauto is like the one I have? I'll keep searching. LOL
64 54 1 381 395
Cheers,
Richard Fitz
vB code is On
e39 aux fan temp sensor Xero 5-Series (E12,E28, E34, E39, E60) 0 02-16-2007 12:00 AM
part number for ac and aux fan relays(already did search and called dealer miami325e 3-Series (E36) 12 06-15-2006 08:24 PM
aux fan miami325e 3-Series (E36) 7 06-14-2006 01:20 PM
HELP: Auxiliary fan not working. A/C works intermittently coheed 3-Series (E36) 6 06-01-2006 01:41 AM
waterpump and fan? eclipsevrl 3-Series (E36) 3 09-30-2005 03:18 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
