i have a 1987 bmw 325i covertible it won't start engine rotates but there is no spark i put a new timing belt,ecu,pulse sensor(crankshaft position sensor),cap and rotor it will start once in a while and run good for like 1 hour then it cuts right out now no spark and won't start plus when u turn the key on the check engine light don't come on and when and if it does thats when it will start also can't hear fuel pumps unless car starts or i jump the realay do u hear them when u click the key on? any help would be appriciated thanks alot
Your post is really hard to read and fully understand. Anyways, have you tried new spark plugs? I check those right after the battery and the distributor. Not too sure about what you mean with hearing the fuel pump.
thank i'll try new plugs but im not getting spark at the coil either and i,ve tried a new coil and still no spark what do i check on the battery and distributor?
Well make sure the battery is charged enough and that the battery terminals are clean and the battery cables are tightened to the terminal and clean. Then make sure the distributor is clean (wd40 spray inside if moisture inside) and that the rotor is not broken, after that it is either a wiring problem or you might have to take it to the shop.
Also check inside the distributor cap for "tracking" or physical cracks...
Pull out a spark plug and reconnect it to its lead, turn the motor over (with the plug body touching the engine to ground/earth it) and look for a spark and notice its colour (should be a lovely blue !!
No Spark = electrical
Spark = fuelling or timing
__________________ Eso es todo! Please press the "REP" button if you are happy with your response/answer...
Please JOIN, or just have a look... Its Totally FREE... BMW Part Market
Possibly a loose connection somewhere
Make yourself a test lamp and see if you actually have power at the coil
Look for loose fuses and relays and connectors.Give connectors a wriggle and see what happens.
Not familiar with the 3 series but just had an intermittent fault with my daily drive (which I hope has been fixed) due to a loose connector at the ECU causing spark problems.
__________________ My daily is a Mitsubishi HSGR (but I wouldn't mind an e34 525i)
the three relays on the driver side strut tower does anyone know what the one closest to the front of the car is for? or called cause i think thats what is causing the problem but i don't know what it controls so i can't get a new one it is the only five prong relay in the car
I had this same problem. I replaced the fuel pump and boom everything is fine.
