| OK you kinda lost me in your description...
So youre basicly saying the car has like no power? Did this start happening the moment after you did the burnout?
As always, check the basics first. Spark plugs, plug wires, cap and rotor, vacuum hoses, do a compression and cylinder leakdown test to make sure your internals are ok...
__________________ <span style='font-size:8pt;line-height:100%'>James
'91 318is</span> |
