help 1987 325e 2.7 5spd - BMW Forum - BimmerWerkz.com
Old 08-24-2009, 03:57 PM   #1 (permalink)
jdlower is on a distinguished road
Question help 1987 325e 2.7 5spd
recently acquired my first bimmer for $1300,(1987 325e 6cyl) overall in good shape, 182k. i've put in a new fuel filter, last owner just did platinum plugs. When i start the car and say hold the rev at 3000 rpm it will drop to 2700 and go back up and repeat, same flux happens at idle speed. Any ideas? also, manual crank sunroof is incomplete but rails spin, the black clips move up and down the rails but are broken on one side and missing on the other. I want to put a salvage roof in, do you have to remove headliner to remove the tracks that go into the roof of the car. any feed back helps thanks, jeff
jdlower is offline   Reply With Quote
Old 08-24-2009, 04:10 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Arrow
1) platinum plugs DO NOT work well for this bimmer series. Whe you can i suggest you revert back to the factory specified copper core plugs.
2) what about air filter? clean?
3) there's no reason for u to rev your engine at 3000rpm when stationary for extended periods of time, and there is a rev limiter circuit in place that will keep ur engine from overshooting it's limits, depending on how your engine sensors feed info to the injection brain(DME/ECU).
** in place of stationary revving... do the driveability test instead. take the car out for a drive and run it to 3000rpm in gear(load). if it pulls cleanly. you are OK!
erratic idle (say +/- 750rpm) - now that's a different issue. if the idle is unstable, your frst line of suspect will be dirty ICV, MAF meter, and throttle body. Clean those parts first with carb cleaner and re-test before thinking that parts are faulty.
Old 08-24-2009, 08:40 PM   #3 (permalink)
+1, dump the plugs and go back to stock. These cars hate anything but stock. This may be the issue itself.
FCP Groton
877-634-0063 | info@fcpgroton.com
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
FCPGroton is offline   Reply With Quote
Old 08-24-2009, 10:52 PM   #4 (permalink)
thanks, actually i may have been over reacting and it just might have been a little cold this morning seems to be idling fine now just sometimes i feel a short lag while i'm driving..... will keep stock plugs in mind thanks guys
Old 08-24-2009, 11:45 PM   #5 (permalink)
Cool, hope it keeps running nicely.
Old 08-25-2009, 03:38 PM   #6 (permalink)
I would still swap out those plugs. They cause nothing but trouble.
FCP Groton
Old 08-25-2009, 04:13 PM   #7 (permalink)
k.sidlosky's Avatar
Car: 06 Ranger, 03 Accord, 96 m3 s52!
k.sidlosky is on a distinguished road
Send a message via AIM to k.sidlosky
The cold does play a big part in the issue. I don't see why everyone has problems with there plugs, I've got iridium platy 4's and they havn't caused me any trouble.
|Dinan Intake|Schrick Cams|24lb Injectors|809 HFM|M50 Manifold|TMS Stage IV+|Dinan Strut Brace|Samco Hoses|UUC Pulley||UUC SSK DSSR|DDM Coilovers|Fikse FM10|Brembo Rotors|Hawk Pads|AA Exhaust|Alpine|Audiobahn|Sony|
k.sidlosky is offline   Reply With Quote
Old 08-25-2009, 04:18 PM   #8 (permalink)
ya im not so sure why such plug drama either..... i'm not a rocket scientist but it seems as plugs serve the same function if gapped right, and a better plug seems like it yield better results
Old 08-25-2009, 10:27 PM   #9 (permalink)
AE86PandaDuda's Avatar
Car: '79 320-6 (needs some work)
AE86PandaDuda is on a distinguished road
Send a message via AIM to AE86PandaDuda
i hate platinum since i can't adjust it. the plain ones are better in my opinion since you dont need a new set every time you want to adjust the gapping for drivability and performance.
AE86PandaDuda is offline   Reply With Quote
Old 08-26-2009, 08:01 PM   #10 (permalink)
I thought the same thing until i got my Volvo 850. The car hated the 15 dollar a plug indiums that it came with. Swapped them out for the 1.50 copper plugs and she has been happy since.
FCP Groton
1987 325e alternator?? Riley87325e 3-Series (E21, E30) 4 09-10-2009 06:12 PM
FS:1987 325iS 5spd, 198k runs/drives NJ 1200$ nyne Cars For Sale 11 05-15-2008 10:15 PM
F/s 85 325e 5spd $1500 Obo turbo325e Cars For Sale 7 02-21-2008 04:41 PM
1987 BMW 325 Convertible 5SPD Red Leather - $3000 OBO in NY tommygun124 Cars For Sale 3 02-04-2007 10:16 PM
1987 BMW 325is 2.5 I6 5spd FOR SALE! Spiders Cars For Sale 5 07-10-2006 12:19 PM
