Heater Core Woes - BMW Forum - BimmerWerkz.com
Old 01-12-2008, 12:27 AM   #1 (permalink)
Matty is an unknown quantity at this point
Heater Core Woes
So today I replaced my 1985 318s faulty heater core, and while I was at it I put in a new heater valve. It was actually quite easy, at least more so than I was expecting. Now the heater does in fact work, but a VERY weird sound has started. A knocking that gets faster as the engine get higher. It is not coming from the engine compartment. It is coming from the heater core / surrounding area. I don't know what would be making this noise other than the new valve. It does not make this sound when I turn the heat all the way down to cold.
Two side notes to this. My battery is not holding a charge, or I haven't driven it enough to get it charged back up (it sat a little while). And also I removed what appears to be an axillary thermostat that was in the line between the engine block and the heater core inlet pipes in the engine compartment. I had heard this was unnecessary. Was I wrong? Was that not a thermostat? Could a low battery be causing the valve to malfunction?
So any ideas would be great, I didn't even start to try and figure it out as it got dark out and I was burned from replacing everything all day.
Matty is offline   Reply With Quote
BMW 520i Heater Core Replacement Michael520i 5-Series (E12,E28, E34, E39, E60) 0 05-26-2006 07:41 AM
Heater Core ? walshja 3-Series (E36) 8 01-19-2005 05:39 PM
Heater Core Problems? emmceethree 3-Series (E21, E30) 0 01-13-2005 12:46 PM
Heater Core Replacement eric wiens 3-Series (E36) 9 10-16-2004 08:10 PM
Heater Core komodo 3-Series (E36) 2 08-08-2004 05:03 PM
