Heat Sheild - BMW Forum - BimmerWerkz.com
Old 02-22-2005, 06:51 PM   #1 (permalink)
Bmw1990's Avatar
Bmw1990 can only hope to improve
Send a message via AIM to Bmw1990
I am about to get a cold air intake for my E30 and i want to get a heatshield to make it a true cold air intake anyone know where i can get one???
I found one here, http://www.mmsport.s5.com/e30.html, but the only way you can order from them is through outlook express, I dont have that shit. I am thinking about making my own if i can't find one... thanks
<img src='http://img127.imageshack.us/img127/4284/bmwlogo2new17jy.jpg' border='0' alt='user posted image' />
Black 4 door 1990 325i
15&quot;x7.5 Ronal LS-wrapped in 205/50-15 Bridgestone Potenza G009
Bmw1990 is offline   Reply With Quote
Old 02-22-2005, 07:29 PM   #2 (permalink)
Kowalski's Avatar
[snapback]297321[/snapback]
i think like 90% of the people who put heat shields on make their own heat shields so id go with that as well.
264* roatation and 388 lift
Old 02-22-2005, 07:54 PM   #3 (permalink)
Bmw1990's Avatar
Yea I work at a tool and die shop so all the tools are available, I think i will end up doing that. Ill save some money in the process.
Old 02-22-2005, 08:25 PM   #4 (permalink)
87 325iS is an unknown quantity at this point
Too bad it's not going to give you any gains.
Amberfire 2000 Dodge Dakota R/T
Rusted, fallling apart Alpine White 1987 325iS - Gone but not forgotten
<img src='http://img.photobucket.com/albums/v255/HeilSova/Sig.jpg' border='0' alt='user posted image' />
87 325iS is offline   Reply With Quote
Old 02-23-2005, 01:16 AM   #5 (permalink)
guywithblack88e30's Avatar
guywithblack88e30 is an unknown quantity at this point
thats not for cold air intake people get it mixed up all the time thats just a intake shield not cold air intake a true cold air intake runs under engine behind lower front bumper. still you'll just get a throaty sound but it is a nice sound thou
Member of got its raining(in Members Lounge) to 100, 237, 250, &amp; 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
guywithblack88e30 is offline   Reply With Quote
Old 02-23-2005, 05:05 PM   #6 (permalink)
Bmw1990's Avatar
[snapback]297371[/snapback]
I am not trying to get any gains out of the filter. I am not impressed with BMW's design on the stock air box, that is all.
Old 02-23-2005, 05:57 PM   #7 (permalink)
a cold air intake does not have to run down to your bumber so you can hydro-lock your engine when going through a puddle, if you get cold air then it is a cold air intake, which is what a heat shield does, plus it eliminates your intake having to battle with your fan for air, ive actually read a study that said that the air down closest to the ground can be hotter than if you just have it up where it is supposed to be with a heat shield, especially on a track
Old 02-23-2005, 08:28 PM   #8 (permalink)
Originally posted by Bmw1990+Feb 23 2005, 05:05 PM--><div class='quotetop'>QUOTE(Bmw1990 @ Feb 23 2005, 05:05 PM)</div><div class='quotemain'><!--QuoteBegin-87 325iS@Feb 22 2005, 08:25 PM
[snapback]297939[/snapback]
[/b][/quote]
If you replace the airbox with a cone filter and get no gains, then i'd say BMW's airbox design is pretty damn good. I don't understand what you don't like about it.
Old 02-23-2005, 11:16 PM   #9 (permalink)
Kowalski's Avatar
Originally posted by 87 325iS+Feb 23 2005, 07:28 PM--><div class='quotetop'>QUOTE(87 325iS @ Feb 23 2005, 07:28 PM)</div><div class='quotemain'>
[snapback]298071[/snapback]
[/b][/quote]
they look pretty damn ugly if i say so myself, especialy when they age... anyways a nice pollished pipe with a cone filter would look 100 times better then the airbox. not to mention you would get better flow into the aircleaner because that little 2 inch hole isn't verry impresive. i just drilled the hell out of the bottom of my airbox, sounds throatier and better flow and im going to make a cold air kit in a month or so.
Old 02-24-2005, 02:56 AM   #10 (permalink)
[snapback]297979[/snapback]
technically a cold air intake is not a cone sitting next to engine heat shield or not a cold air intake is even the ones that go thru where high beam went at one time too but a cold air intake is not one sitting next to engine in heat shield reason being is after the engine has been running a long time even the air that comes from around heat shield is gonna be hot with COLD air intake the air is ALMOST always not coming from engine hence name "cold air intake" not "cold air before engine gets hot intake"
Old 02-24-2005, 02:58 AM   #11 (permalink)
if i were and you don't really use ur high beams i would do a high beam cold air intake like bimmin 88 it looks sweet i would do it myself but my angels won't look right if i did that
Old 02-24-2005, 12:04 PM   #12 (permalink)
Kowalski's Avatar
[snapback]298273[/snapback]
yeah iv thought about that i put bosch H4's in the outside lights 75w lows and 95w highs and the middles are still the seal beams and they don't help at all when the highs are on cause they're so dim anyways i guess i could pull one out... but then i would look like a turbo imposter... but the air is still going to heat up through the intake and the throttle body heater and the vacume heaters so really its not going to be that much of a temp change unless its winter which winter is almost over now... anyways ima gona go fix my car.
Old 02-24-2005, 12:36 PM   #13 (permalink)
whats kool bout the high beam intakes is the faster you go the more forced air thats going thru to intake. say if your going 60 you have 60 mph wind coming thru
Old 02-24-2005, 02:36 PM   #14 (permalink)
but you still dont get any power from the high beam intake, i read that it gives you like .01 psi more which is nothing in terms of power. regardless of where you put your intake the air isnt gonna be ice cold once your engine heats up, and its not like an intake is really a big power booster anyways, but a heat shield is the cheapest and easiest way to cool down the air goin in. Plus with my cone filter bolted to my AFM it is right behind my high beam so its not like i would have to move it, i would just have to take out my light. they do sound better though
Old 02-25-2005, 12:18 AM   #15 (permalink)
Kowalski's Avatar
[snapback]298518[/snapback]
you could get one of those ebay hood scoops and make it functional they're about a 1 inch scoop nothing too ricy, but if you put a filter on that then you have forced induction on the hood plus a shorter path for the air to run into the intake giving it less time to heat up and better intake flow... just a thought i duno if id like a scoop on it maybe a small revers one... who knows.
Heat only coming out of drivers side Yankees368 5-Series (E12,E28, E34, E39, E60) 14 12-06-2005 01:12 PM
Removing Heat Sheild Live_the_Curves 3-Series (E36) 9 03-09-2005 11:56 AM
Hey Guys, Just A Quick Question Regarding My Heat bimmerfan620 3-Series (E36) 6 10-29-2004 02:52 PM
Heat? ghettozn 3-Series (E36) 3 08-02-2004 08:22 PM
no heat 1991 BMW 318i will1506 3-Series (E21, E30) 9 02-27-2004 10:58 AM
