Headlight/Foglight Stroke - BMW Forum - BimmerWerkz.com
Old 01-19-2006, 04:27 PM   #1 (permalink)
Neil Paz is on a distinguished road
Cool Headlight/Foglight Stroke
A few days ago I noticed that my right headlight had gone out. "No big deal," I thought, "headlights burn out." Then I noticed that the fog light, on the same side as the headlight that had gone out, was also out. When I turn on the high-beams though, all four headlights come on (but still not the fog light).
Is there some connection between these two lights, for instance, will the fog light going out affect the headlight (low-beam) on that same side?
What should I check first? Fuse, relay, headlight bulb (even though it lights when in high-beam mode), fog light bulb, switch???
Thanks for your advice ahead of time,
Neil
1984 BMW 325e (<200k milage)
Neil Paz is offline   Reply With Quote
Old 01-19-2006, 08:16 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
The headlights you have are dual element, which means there are 2 light elements in the low beam headlight, one for low and one for high. It sounds like the low has burnt out and just by chance the fog light on the same side doesn't work. I would just get a new H3 bulb for the fog light and a new 5 3/4" sealed beam for the headlight and see if that fixes the problem. Most any parts store will have these.
My M50 Powered E30 Page
Old 01-20-2006, 08:07 AM   #3 (permalink)
luckycat's Avatar
luckycat is an unknown quantity at this point
AJ's correct. Keep in mind that most Bmw fog lights go out when you turn on the high beams. Headlights are controled by relays also, try substitution.
luckycat is offline   Reply With Quote
Old 01-20-2006, 08:55 AM   #4 (permalink)
Thanks guys...I'll try the sealed beam. I just wanted to confirm.
Old 01-23-2006, 11:32 AM   #5 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
Just this morning on my way to work, my right low beam blew....I've been looking on Bav Auto for a replacement one and the one they say is for my car looks a bit different then the stock ones that are on it now, and they cost around $120.
The ones that looks closest to may car cost around $10 BUT are for cars from production 6/89 mine is from 2/89.
So I'm a little confused as to which ones I should get...neither one looks like my current ones...
I drive a 89 325i convertable by the way...
yammahamma is offline   Reply With Quote
Old 01-23-2006, 11:56 AM   #6 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
If you have the elipsoid headlights then you can just change the bulb which is a 9006 for the low beam and a 9005 for the high.
Old 01-23-2006, 12:09 PM   #7 (permalink)
yammahamma's Avatar
Car: '01 330i
I'll go check but I'm pretty sure the bulb and the lens are one solid piece...I don't know if that makes it elipsoid or what...
1988 75a suffered stroke Rhon 1,6,7,8 - Series and Mini Cooper 0 05-03-2004 02:14 AM
