Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 05-13-2005, 10:54 AM   #1 (permalink)
77th Gear Member
325eXTATIC's Avatar
Photos: 0
325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light
Send a message via ICQ to 325eXTATIC Send a message via AIM to 325eXTATIC Send a message via MSN to 325eXTATIC Send a message via Yahoo to 325eXTATIC
Hello all, got a bit of a problem...
My 86 325e has always been a bit hard to start, but this morning, it would NOT start. It cranks and cranks but it won't catch. Under the hood there was a small leak of fuel from the fuel line into the Cold Start Injector on the intake manifold. I tightened the hose connection, and cleaned the connector and dried it, but no success. Do I need to replace the whole CSI? Ideas? Suggestions?
Josh W
86 325e w/Dinan ECU
Not currently on the Bimmer kick. Drivin' a 2003 Silver Civic at the moment, but I am STILL the Founding Member of the "325eXTATIC You're my hero" club.
Originally Posted by <b>superdeadman</b><br>Josh W. IS my hero!
325eXTATIC is offline   Reply With Quote
Old 05-17-2005, 03:45 PM   #2 (permalink)
Photos: 0
Any petrol engine only needs 3 things to run spark, fuel and compression, check these and one will be missing.
If you need help testing these send me a personal message through the site and I’ll do a step-by-step
Old 05-18-2005, 11:51 AM   #3 (permalink)
77th Gear Member
325eXTATIC's Avatar
Photos: 0
[snapback]345288[/snapback]
Compression is good, Fire is good, the only thing I haven't verified is fuel delivery. What method would you recommend to check that? Should I disconnect the fuel line from the fuel rail and shoot it into a jar while I turn the key to the on position? Or is there another option to verify fuel delivery? I saw a Cold Start Injector test procedure in my service manual, but haven't had time to do it, do you think that could be the problem? Or do you think it is more likely a fuel pump problem?
Thanks for the response! I was starting to think I was being ignored!
Josh W
86 325e w/Dinan ECU
Old 05-20-2005, 06:30 AM   #4 (permalink)
Photos: 0
Yes check the fuel as you say the only other way is with a pressure gauge in line, it could well be a fuel pump fault. But if you have pressure and still have dry plug then the injectors may not be working on cranking listen to the injector they should tick (use a screwdriver to listen if you’re unsure)
vB code is On
323i Wouldn't Start TRuckee 3-Series (E46, E90) 8 12-04-2005 02:41 PM
Run Out Of Gas Wound Start (help) p_villa3030 6,7,8,X,Z - Series and Mini Cooper 0 04-08-2005 12:48 AM
'89 325i Hard Start 1989BMW325i 3-Series (E21, E30) 2 02-25-2005 10:39 AM
528i Will Not Start Intermitenly Help mike mulligan 5-Series (E12,E28, E34, E39, E60) 4 09-27-2004 08:20 AM
M3 Squeaks- hard start TB-M3 M-Series (M3, M5, M6) 1 10-06-2003 02:55 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
