Guage cluster swapping, difficulties. Cue Starmavin... - BMW Forum - BimmerWerkz.com
Old 04-17-2007, 10:24 PM   #1 (permalink)
Car: 1984 BMW 318i
daklunk is on a distinguished road
Question Guage cluster swapping, difficulties. Cue Starmavin...
I have an '84 318i and the original cluster got lost, so I had to buy a replacement, from a 91 iX. I read a bit about coding plugs and such, found out about earlier pins in the back, the plastic plugs in the front on the newer ones. So anyway, I realize there isn't an actual plastic coding plug for the M10, but I was told that the plug from an M42 or S14 cluster would work fine. Is this right? Or do I need to search for a mint 318i cluster?
Thanks
daklunk is offline   Reply With Quote
Old 04-19-2007, 12:24 AM   #2 (permalink)
Car: Opening soon:
All 1/1986 and older have the engine code plug inside, 1/1986 and up the code plug were made external for easy changing. However the coding chip is specific to each engine type, injector type, tire size, fuel tank and reserve capacity. Try it, what do you have to loose, however the tach may read wrong.
Old 04-20-2007, 09:20 PM   #3 (permalink)
Car: 1984 BMW 318i
OK, great, thank you very much! Was hoping that I could for sure use any 4 cyl plug, but now at least I know. If I can turn one up for cheap, I'll try it...
Thanks!
Guage Cluster Battery offabroadway 3-Series (E21, E30) 0 04-15-2005 11:20 AM
Odometer On Cluster Guage Not Working SemiPerfect 3-Series (E36) 4 10-13-2004 01:28 PM
Electronic Guage Cluster Stew455 1,6,7,8 - Series and Mini Cooper 1 06-10-2004 03:51 PM
2000 m3 Guage cluster... m3 or 3 series? Braymond Classifieds Sell & Buy 3 04-06-2004 05:04 PM
