Green Indacator Lights - BMW Forum - BimmerWerkz.com
Old 04-25-2004, 03:22 AM   #1 (permalink)
SensiStar325i is an unknown quantity at this point
[COLOR=blue] Just curious about the green lights that are supposed to warn you of needed service. I am now down to 2 green lights, btw 89 325i, but i have beenkeeping up on maintenance myself. I do not own one of those things that reset the lights.. Am I possibly missing something and my baby may be soon to fail me, or do i just need that reset doohicky.
Appreciate any feedback
SensiStar325i is offline   Reply With Quote
Old 04-25-2004, 07:03 AM   #2 (permalink)
CiscoKid's Avatar
if you dont reset, thats fine... just follow the maintence schedule in the manual. The only this is you will have to look at those red light when you start up. If you can find someone with a reset, reset it, and you should be good for 7500 miles
Old 04-25-2004, 09:31 AM   #3 (permalink)
Trob is an unknown quantity at this point
Thats what I wanted to ask..what is the deal with the lights on the dash exactly? Damn I wish I had an owners manual!! ghead
91 BMW 325 IX
BLACK
2 DOOR
5 SPEED
THE MORE RARE IT IS THE MORE IT COSTS TO FIX!
95 BMW 325 IS
GREEN
2 DOOR
5 SPEED
LET THE MODS BEGIN
Trob is offline   Reply With Quote
Old 04-25-2004, 11:11 AM   #4 (permalink)
SI reset and batteries
With the ignition switch at (position two) and the engine not running, grounding pin seven #7 of the diagnostic connector to pin one #1 for approximately three (3) seconds will reset the oil service lights. Grounding pin seven #7 to pin one #1 for approximately twelve (12) seconds will do an inspection service reset.
More information.
http://www.specialistcarsbmw.co.uk/stevena...vice_lights.htm
http://www.unofficialbmw.com/images/reset1.gif
1. Ground
4. Temperature sensor
7. Reset
8. TDC sensor yellow
9. TDC sensor shield
10.TDC sensor black
11.Start signal
12.Alternator charging excitation voltage
13.Ignition coil
14.Alternator charging supply current
15.Oxygen Heater
It will signal an oil change need between 5k and 7k depending on your indicated speed since the last reset. It will signal stealer inspections at all the predesignated miles.
http://www.eskimo.com/~dalus/bmw/e36/elect...ice_lights.html
SI Board Swap Out
Last but not least - the SI Board. Above is a new SI Board with lithium batteries and below is the old one. Note the blown battery on the old SI Board (green circle). The light blue rectangle shows the actual service indicator LED's which appear on your dash display. These LED's are mounted on a separate circuit board which must be pulled out of the old SI Board and plugged into the new one. This is an easy task. The purple arrow shows the orientation of the SI Board relative to the driver.
If it fails to reset then you need batteries.
Varta battery 500RST OE part.
Radio Shack: part number 23-191: $6.49 for set of two; they come w/solder tabs on them.
1.2 volts / 700mAh
Charge fully B4 installation on SI board.
Consider mounting batteries "remotely" under dash, etc. in separate holder for easy removal in future (i.e. not pulling the console out and apart); you can buy a plastic holder at RS. Run leadwires from holder to SI board connections. Makes life easy if you ever need to replace batteries again.
From Radio Shack, get:
1) You'll need a twin AA battery holder ($3)
2) 2 AA NiCAD rechargeable batteries ($6)
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Old 04-25-2004, 11:21 AM   #5 (permalink)
CiscoKid's Avatar
linky brokeny
Old 04-25-2004, 11:31 AM   #6 (permalink)
CiscoKid's Avatar
nvm... heres the working link
http://www.unofficialbmw.com/e36/electrica...ice_lights.html
Old 04-25-2004, 02:42 PM   #7 (permalink)
BimmerKris's Avatar
BimmerKris is an unknown quantity at this point
More information.
1. Ground
7. Reset
10.TDC sensor black
11.Start signal
13.Ignition coil
15.Oxygen Heater
SI Board Swap Out
1.2 volts / 700mAh
Later,
Is the one for the temp sender, for the OBC. Can i reset that one tho change my temp so it doesn't say -30 all the time
<img src='http://bmwforums.penguinstudios.com/BimmerKris/salesig%20copy.jpg' border='0' alt='user posted image' />
<a href='http://www.acantha.ca' target='_blank'>www.acantha.ca</a> 100% thrash your face off metal
BimmerKris is offline   Reply With Quote
Green Service Lights? Silvr02 5-Series (E12,E28, E34, E39, E60) 1 08-02-2005 08:30 PM
The Hunt For The Purpose Of The Green Relay. Kowalski 3-Series (E21, E30) 2 06-01-2005 08:27 PM
Green E36's mrkbik 3-Series (E36) 25 02-27-2005 01:00 PM
The Green Lights For Oil Change Henri 3-Series (E36) 13 10-23-2004 09:49 AM
