| Dude I recommend you research this deeply or have a professional install it for you, no offense but you seem a little down witted on the mechanical end, but what do I know... You can pick up a Haynes or Bentley manual to assist you to some degree... Good Luck
From what I know you cannot change the synchro gear to anything else due to the fact it would throw off all the other gears. If your engine sounds like its ganna blow in a overdrive 5 speed gearbox then there is a problem, the swap from the 4 speed to the 5 speed is ment to get rid of the high RPM's at highway speeds.
__________________ <img src='http://e21.tricord.cjb.net/members/cjpix/bim1_050204.jpg' border='0' alt='user posted image' /> |
