Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 04-23-2005, 10:50 PM   #1 (permalink)
Photos: 0
offabroadway is an unknown quantity at this point
Hey everyone. Funny story. Today my car wouldn't come out of Park for half an hour. Had to have my friend rescue me. Second time he's done this in the last month. I feel stupid about this car.
So, here's the plan. This, by the way, is the car going under half-resto with a possible manual tranny and other goodies. After realizing how deadly shop rates are (I knew this already, but the other driving force behind this is I want to learn to work on the car myself. I don't trust other's easily with my possessions) I'd like to do my service and maintenance myself.
First job, pull and replace timing belt, and accessory drive belts. Second is an oil change.
Are Bentley manuals the best DIY guide out there? Is there a better one for my purposes? And what are the basic tools I'm going to need to work on the car? I'm starting from scratch here... assume I own no tools (I own very little) and what would you suggest?
Thanks for the input.
<img src='http://www3.telus.net/drewdlespace/bmw/banner.jpg' border='0' alt='user posted image' />
Changed the car's name, now it's - Roxanne -1985 325e
offabroadway is offline   Reply With Quote
Old 04-24-2005, 11:14 AM   #2 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
Photos: 5
The sky is the limit. I'm no expert, for sure, but I'm not afraid to work on my own vehicles. I've done all the maintenance on my E30, and it's pretty straight forward.
I have 3 sources for reference
1. Haynes Manual
2. Bentley Manual
3. BMW Enthusiast's Companion
By far, I would say that the Bentley is the best. Of course, I try and use the internet for stuff as well.
You're going to need a metric socket set for sure. All sizes. (You're going to use 10, 13, 17, 19mm a lot) I have combination wrenches, screwdrivers, and allen (and torx) wrenches. I have some other assorted tools, but you're basically going to have to start with a good set of each of the above. Also, before you go ahead and start on that timing belt, ensure you have something that is thin and large enough to get the fan and clutch off. I'm pretty sure it's a 32 mm nut, and it only needs to be broken loose, it will hand loosen from then on, but if you don't have something to get that off, your maintenance will come to a screeching halt.
Hope this helps.
oh, and about your transmission, did you check your fluid? (I'm sure you did)
My BMW Blog
Old 04-24-2005, 11:31 AM   #3 (permalink)
schneider252's Avatar
Photos: 0
www.E30tech.com
www.r3vlimited.com
www.14.net
Old 04-24-2005, 12:51 PM   #4 (permalink)
Photos: 0
Yep, checked the fluid. Sat on the hood and talked to it for a while, under my breath, trying to figure out why she'd strand me like that. Then I went back and looked at my shifter control again. The handle came off in my hand, and I looked at it and the linkage inside the stick, and realized it was simple: the pin on the handle hadn't stayed in the linkage. Porbably because the screw from the handle has gone MIA. So I jigged it back on, and she drove beautifully.
Today I'm fixing the handle with a nice new screw. Don't want that happening again.
So, metric sockets, allen wrenches, screwdrivers, and something thin to take the bolts
off the fan. Haynes and Bentley. Got it. Wish me luck.
Hey... wait a sec. Maybe I should warm up by doing the oil first. Simple task right? The car has a FRAM filter on it... I've heard bad things about FRAM filters. Anyone suggest a better make? Thanks.
Old 04-24-2005, 02:27 PM   #5 (permalink)
Photos: 0
Spend the money and by a dealer filter and good oil Castrol or alike it’s false economy to buy cheap bits likewise the timing belt either dearer pert or Gates they make the belts for BMW Make sure you read the instruction carefully for the timing belt because it’s expensive if you get it wrong.
As for tool don’t buy the best and don’t buy the cheapest they’re so good budget tool around now I’m a Brit BMW tech so can’t tell you where to buy I own £25,000.00 worth of tool and still don’t have everything.
To start:
1. 3/8 drive socket set 8-24mm with extensions
2. small ¼ drive socket set 5-10
3. Set screw driver
4. set combination spanner 6-24mm
5. A thin 32mm spanner (fan coupling left hand tread)
6. 1 1/12 lb ball pain hammer
7. set of pliers including side cutters pointy nose and pipe grips
Allen keys and torq bits etc by as you needed i.e. not many torq screws on older cars
If you need any specialist help email me through the site and I’ll do my best
Old 04-24-2005, 05:34 PM   #6 (permalink)
Photos: 0
llll1l1ll is an unknown quantity at this point
Send a message via AIM to llll1l1ll
A set of really strong knuckles.
Three rocker arms later and I still haven't learned my lesson!
llll1l1ll is offline   Reply With Quote
Old 04-25-2005, 06:04 PM   #7 (permalink)
WoW killed my social life
nukeduster's Avatar
Car: 95 Daytona Violet M3
Photos: 0
[snapback]337243[/snapback]
torque wrench and breaker bar. and spend a little extra on your ratchet set, a cheap ratchet in particular can be a PITA to use.
make sure to get deep sockets as well as normal sockets in metric.
a ratcheting screw driver can save alot of grief too.
craftsman tools are good IMO because if you ever break a tool (if you work on cars long enough, trust me, even lifetime warranty tools break) you dont have to send out the tool for replacement like you have to with Snap On. you can just drop by any Sears and they replace it on the spot without a receipt.
When you fight, you don't fight for abstract values like the flag, or the nation, or democracy. You fight for your buddy. You fight to keep him alive, and he fights to keep you alive, and you go on that way, day after day, battle after battle. And when one of your buddies dies, something inside you dies as well. But you go on. You fight, so that his death isn't meaningless, his sacrifice isn't for nothing.
-Dick Marcinko
Old 04-25-2005, 08:35 PM   #8 (permalink)
Photos: 0
yes i need to make a trip to sears
craftsman ftw!
Old 04-26-2005, 11:59 AM   #9 (permalink)
Nostaticatall's Avatar
Photos: 0
Nostaticatall is an unknown quantity at this point
" I've heard bad things about FRAM filters. Anyone suggest a better make? Thanks. "
Mann filters .
Napa filters good too.
<span style='font-family:Times'>1987 325 is
Color:Red
Mods: BFG Traction T/A's(more to come)
Runs like a hyiena on steroids....</span>
Nostaticatall is offline   Reply With Quote
vB code is On
1997 328i Maintenance Questions Larry Horne 3-Series (E36) 8 10-12-2005 12:04 AM
Maintenance And Repair Shop frank-e 5-Series (E12,E28, E34, E39, E60) 1 01-04-2005 07:34 PM
Maintenance query walt525tour 3-Series (E46, E90) 2 08-16-2004 07:24 AM
Maintenance Costs Alpha_Man 3-Series (E36) 9 06-23-2004 05:41 PM
Basic Maintenance 88'325 3-Series (E21, E30) 4 05-21-2004 02:52 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
