Getting To Much Fuel..aprently... - BMW Forum - BimmerWerkz.com
post #1 of 12 (permalink) Old 04-16-2005, 10:24 PM Thread Starter
W00T
Numark318i's Avatar
Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute Numark318i has a reputation beyond repute
ok so my exhaust was vibrating cause my CAT heat shield was punctured...so i went to a muffler shop to have it changed...he told me its fine and that i should jsut cut off the heat shiled which was making the weird noise during acceleration. I also noticed the CAT/Exhaust had a weird smell to it...cant describe it. I know its coming from exhaust though. So the muffler guy told me that the engines getting to much fuel....and its not burning it all. Could this be due to my TMS chip..since it adds more fuel and air aprently to my mixture?
I would think they thought about this kind of problem....
so what do u guys think..whats the smell from.
If its gettting to much fuel how can i fix it?
Should i take it to a mechanic..my dad said he might be able to adjust it...
Numark318i is offline
post #2 of 12 (permalink) Old 04-17-2005, 10:28 AM
Bmw1990's Avatar
Bmw1990 can only hope to improve
Send a message via AIM to Bmw1990
Does the smell, smell like rotten eggs kind of? That smell is one sign of a cat going bad.
<img src='http://img127.imageshack.us/img127/4284/bmwlogo2new17jy.jpg' border='0' alt='user posted image' />
Black 4 door 1990 325i
15&quot;x7.5 Ronal LS-wrapped in 205/50-15 Bridgestone Potenza G009
Bmw1990 is offline
post #3 of 12 (permalink) Old 04-17-2005, 06:04 PM Thread Starter
W00T
Numark318i's Avatar
not of rotten eggs yet....the guy said my cat will go bad though if i dont fix the problem....maybe ill cut the whole thing off after i fix the engine prob and just get a new exhaust.
post #4 of 12 (permalink) Old 04-17-2005, 06:51 PM
RealBMW 02's Avatar
RealBMW 02 is an unknown quantity at this point
Send a message via AIM to RealBMW 02
you can't cut off the cat...won't pass smog without it.
But you chip could be adding more fuel to your engine to reach a better fuel to air ratio for more power. But not sure how your chip works exactly
<img src='http://files.unitedbimmer.com/ub.c/RealBmw%2002/Sig_ver2.jpg' border='0' alt='user posted image' />
1970 - 2002
Proud Memeber: 30+ year old car club
RealBMW 02 is offline
post #5 of 12 (permalink) Old 04-17-2005, 07:53 PM
Kowalski's Avatar
your engines running rich, check your plugs they might not be providing enough spark to ignight all the fuel. or you could adjust your afm
264* roatation and 388 lift
Kowalski is offline
post #6 of 12 (permalink) Old 04-17-2005, 09:10 PM
BMWJNKY's Avatar
BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute BMWJNKY has a reputation beyond repute
I'd do some new plugs, cap and rotor. Also unless you really know what you are doing don't mess with the AFM, that is the last thing that you should tweak to try and fix an air/fuel ratio problem.
BMWJNKY is offline
post #7 of 12 (permalink) Old 04-18-2005, 07:49 PM Thread Starter
W00T
Numark318i's Avatar
^^sinced i dont know waht an afm is...ill go with spark plugs and cap and rotor
post #8 of 12 (permalink) Old 04-18-2005, 08:43 PM
RealBMW 02's Avatar
The AFM is the air to fuel mixture. But on a computer controlled car with fuel injection you are usually not able to adjust AFM unless you have a stand alone fuel system with a completely adjustable fuel map.
In other words, just get new plugs and see if that helps.
BTW when you take your old plugs out see how they look. They should not be greasy or sooty at the electrode, but rather a dull metal color. If they look like they are still good and have plenty of electrode left, approximately .040-.060" (40-60 thousandths of an inch), then you might be able to just regap them and solve the problem. Check your owners manual for gap length
1970 - 2002
post #9 of 12 (permalink) Old 04-18-2005, 11:56 PM
BMWJNKY's Avatar
[snapback]334487[/snapback]
AFM is the air flow meter. Its the thing attached to the air box in the E30. Later cars have an AFS, air flow sensor, which is just a wire that reads how much air is going into the engine.
BMWJNKY is offline
post #10 of 12 (permalink) Old 04-19-2005, 12:57 AM Thread Starter
W00T
Numark318i's Avatar
Originally posted by RealBMW 02+Apr 18 2005, 06:43 PM--><div class='quotetop'>QUOTE(RealBMW 02 @ Apr 18 2005, 06:43 PM)</div><div class='quotemain'>The AFM is the air to fuel mixture. But on a computer controlled car with fuel injection you are usually not able to adjust AFM unless you have a stand alone fuel system with a completely adjustable fuel map.
[/b]
i see
Now that i think about it i had the plugs changed like 6 months ago..but hell if i know if the guy actually changed them...Ill do it myself this time.
Originally posted by AJ's320i@Apr 18 2005, 09:56 PM
<!--QuoteBegin-RealBMW 02
[snapback]334559[/snapback]
[/quote]
yea ok that makes sence. Yea im not fucking with the computer. Dont u need a new computer system to even try to change shit like that?
post #11 of 12 (permalink) Old 04-19-2005, 11:47 AM
Pandemonium Director
nukeduster's Avatar
nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute nukeduster has a reputation beyond repute
not if you have mad crazy ninja skillz.
nukeduster is offline
post #12 of 12 (permalink) Old 04-19-2005, 09:23 PM
RealBMW 02's Avatar
Originally posted by AJ's320i+Apr 18 2005, 09:56 PM--><div class='quotetop'>QUOTE(AJ's320i @ Apr 18 2005, 09:56 PM)</div><div class='quotemain'><!--QuoteBegin-RealBMW 02@Apr 18 2005, 04:43 PM
The AFM is the air to fuel mixture.*
[/b][/quote]
yes you are correct sir. I was drunk when I replied and the letters seemed to fit :P
1970 - 2002
Fuel Leak ajreich 3-Series (E36) 1 11-13-2005 09:00 AM
Help Urgent Bmw 318is Fuel Flood Help nobrakese36 3-Series (E36) 1 07-26-2005 12:31 AM
whisling sound at fuel filter javieruz 3-Series (E21, E30) 2 04-12-2004 11:17 PM
320i in-tank fuel pump? nightsurfride 3-Series (E21, E30) 1 01-28-2004 11:45 PM
