If you got the differential of the automatic, most are a higher ratio, the converted car may be faster than the BMW made standard shift.
Parts needed includes:
new rear engine seal, SACHS clutch kit, hydraulic components, guibo, transmission mounts, center bearing, shift boot and more.
Used parts include: cleaned and re-painted Getrag 260 transmission, flywheel, driveshaft, shifter platform, and pedal bracket assembly. All parts are here to replace the 4HP22 automatic transmission.
Sample Price: $995.00 in US Dollars
http://www.theeurodepot.com/specials.html
Later,
