| Not positive about the e30, but on the e36, the green wire on the bottom half of the steering column is the ignition wire, you can tap that.
Or, yank the radio (easy enough to get out) tap the swithced ignition lead there, as it's basically the same thing as the aforementioned lead.
__________________ |
