| Gauge cluster wiring problem I have an 87' vert and removed the cluster to inspect wiring due to the speedometer fading in and out and the tachometer not reading correctly, along with the temp sensor not working. When i went to put it back together I realized there were 2 single wires with the yellow stripe with black connectors, and I know they plug into the green connector on the cluster put theres 3 slots. Anyone know what goes where? One wire comes from the right side and travels behind the radio and the other travels to the left and then down to the firewall somewhere. Any help is great, or wiring diagram. Thanks |
