Fuse Keeps On Blowing Off - BMW Forum - BimmerWerkz.com
Old 12-22-2004, 03:54 PM   #1 (permalink)
mantra is an unknown quantity at this point
Thumbs up
Since a couple of days, Fuse No 10 which mainly controls the following:
Seatbelt Warning
Service interval indicator
Tachometer/Fuel Economy Gauges
Gauges/Indicators
Brake Warning System
Back Up Lights
On-Board Computer
Injection Electronics
Active Check Control
The fuse being a 7.5A Fuse keeps on blowing off everytime being replaced by a new one.
I have tried looking for the electrical diagram on the net so as to trace where the problem could be coming from but in vain.
Could anyone PLEASE HELP !!!!
Thanks
mantra
mantra is offline   Reply With Quote
Old 12-22-2004, 04:28 PM   #2 (permalink)
grtmoby is an unknown quantity at this point
This indicates a short circuit on any of the mentioned cirduits. I'd go first and check on the back up lights, injection electronics and then the seatbelts. To confirm it is nothing of the gauges u can simply detach the instrument cluster and check if it will still blow out or not.
HTH...
grtmoby is offline   Reply With Quote
Old 01-06-2005, 02:20 AM   #3 (permalink)
E30DTM87 is an unknown quantity at this point
OK, i had the same problem and i was getting really pissed, so i just put in a 10 instead of a 7.5. haven't had any problems since
E30DTM87 is offline   Reply With Quote
Old 01-06-2005, 10:50 AM   #4 (permalink)
brodee is an unknown quantity at this point
Try pulling your shift boot up and then find the wire in there for the reverse light switch. Try to move the wire around so it has some slack going through the boot.
I did this with mine and it solved the problem.
<img src='http://www.tmdnet.com/bmw/bmwsig4.jpg' border='0' alt='user posted image' />
brodee is offline   Reply With Quote
Old 01-07-2005, 12:11 AM   #5 (permalink)
javieruz's Avatar
javieruz is an unknown quantity at this point
Send a message via ICQ to javieruz Send a message via MSN to javieruz
i believe the tach back lights, etc. are connected with the licence plate lights and the sidemarkers, check all of those since there may be come short... when my tach backlights went out, the licence plate as well as the sidemarkers stopped lighting....
<span style='font-size:13pt;line-height:100%'><span style='font-family:Arial'>'87 325i Convertible</span></span>
javieruz is offline   Reply With Quote
E30 Fuse Box Privateye 3-Series (E21, E30) 5 06-27-2005 09:25 PM
Fuse Blade Terminal Clips szidikj 3-Series (E21, E30) 0 08-16-2004 10:59 AM
Fuse keeps blowing DaveA 3-Series (E36) 7 05-17-2004 01:28 PM
Shorting in a fuse for guages, and other idling. M5power 5-Series (E12,E28, E34, E39, E60) 0 04-10-2004 11:35 PM
