| 1992 BMW 325i Convertible WBABB131XNEC06210
My vehicle has an accessory fuse box attached to the main fuse box. It is intended to allow add-on accessories without tapping into the main fuse box. The fuse box only has the "hot" side fuse blade terminal clip installed. I need 2 cold side fuse blades that I can insert so that I can add fuses and an accessory. Do you have the fuse balde clips available separately? If so please gice part number so I can order. |
