Out side the fuse box are three relays.
they can be moved to different locations.
The only way to know is to check the wire colors.
The five prong is the main relay
RD
RD/WT
GN
BR
BL/RD
Fuel pump relay
RD
RD/WT
GN/VI
BR/GN
o2 sensor heater relay
GN/VI
GN/YL
GY/BR
GN/BU
On the fuel pump relay, short from pin #30 to #87.
This should cause the pump to run if fuse #11 is good.
Later,
