fuel system - BMW Forum - BimmerWerkz.com
Old 12-27-2008, 12:32 PM   #1 (permalink)
richiemaier's Avatar
Car: working on restoration
richiemaier is on a distinguished road
Send a message via Yahoo to richiemaier
fuel system
Ok guys and gals this is probably a stupid question but i need to make sure. Sometimes my car starts and then doesnt. I hear a click under the hood when i turn the key on and it starts. If i dont hear the click it doesnt start. So my question is can i rule out the fuel pump and guess its the fuel pump relay ????
richiemaier is offline   Reply With Quote
Old 12-27-2008, 01:13 PM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
I would say its the starter motor.
Old 12-27-2008, 04:34 PM   #3 (permalink)
no its not the starter motor. The engine cranks and will fire with ether but wont run unless i hear the click when i turn the key to on, not start.
Old 02-19-2009, 03:04 AM   #4 (permalink)
Car: 1982 Bmw 320i E21-M10
fj-cruizer is on a distinguished road
It is problebly the Starter Solinoid...Take apart and clean real good-or-buy replacement for less than$100.00.Eventually you'll be tapping on your starter/solinoid to get her to turn-over...Although I did have one that finally came around on its own and never did have that issue again-the rule of thumb is to repair/replace solonoid.
fj-cruizer is offline   Reply With Quote
Old 02-19-2009, 03:21 AM   #5 (permalink)
HU$TLA's Avatar
Car: 1992 e36 318i metalic blue,sackd
HU$TLA is on a distinguished road
i know this is probly a dumb answer but are ur battery terminals tight? An is ur earth wire connectd?
I had a simular prob thort it was starter motor but it end'd up being the earth wire was loose the bolt had fallen off an it was just hanging there
HU$TLA is offline   Reply With Quote
Old 02-20-2009, 01:42 PM   #6 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Sounds like the Main/DME relay going bad. The 3 relays in a row on the drivers side of the engine compartment it is the one closest to the front of the car, PN 61 36 1 729 004 Another problem this relay will cause is the car will randomly die while driving down the road.
My M50 Powered E30 Page
Old 02-20-2009, 03:35 PM   #7 (permalink)
JdmEuroNorth.'s Avatar
Car: 1984 BMW 318i
JdmEuroNorth. is on a distinguished road
The click you are hearing is the starter solenoid.
it's what you're actually energizing when you push the key to the start position, it closes a contact like a magnet, that have 2 terminals on it. 1 comes from the batter Positive post and the other goes to the starter.
If that solenoid doesn't click power doesn't go to the starter, simple as that.
You just need a new solenoid, hopefully yours is servicable. Good luck.
JdmEuroNorth. is offline   Reply With Quote
84 318i fuel system issue prosavage2600 3-Series (E21, E30) 13 12-07-2008 09:30 PM
fuel system 87325es 3-Series (E21, E30) 0 10-01-2006 01:08 PM
Fuel System Probs scott082 3-Series (E21, E30) 4 07-30-2004 01:05 AM
Fuel System Problems... jdpiper 3-Series (E21, E30) 4 12-10-2003 11:13 AM
