fuel pump Question - BMW Forum - BimmerWerkz.com
Old 07-12-2004, 08:16 PM   #1 (permalink)
bohmer2 is an unknown quantity at this point
I am posting this for my dad, he recently purchased an 88 325 (no letter designation?) he has driven the car off and on for a couple weeks but over the weekend the car just stopped starting. ghead The car will turn over and has spark but there is no fuel being delivered. After running a test light around the engine compartment, he discovered there is no power coming into the fuel pump. The car has had electrical problems with its previous owner having the battery replaced at a chain store and the tech fried the fusable link by putting the battery in backwards. This problem was fixed and the previous owner put another 5K or so on the car. The question is, is there a roll over switch or something similar that may have been tripped that killed power to the fuel pump and therefore stopped fuel delivery?
bohmer2 is offline   Reply With Quote
Old 07-14-2004, 01:18 PM   #2 (permalink)
Thumbs up
OK no replies so I tried to get a little more info from the old man on what all he has checked out. The power problem seems to be different than what I had described. After the car wouldnt start he began testing the fuses in the engine compartment and discovered that there is no power on either side of the fuse that operators the fuel pump.
Does anyone have a wiring diagram or know where we can find a wiring diagram so that we can track down the culprit of this power loss?
And based on information from another site can anyone tell me how to locate the following on the car: DME Main & Fuel pump Relays.
Old 07-14-2004, 03:18 PM   #3 (permalink)
87bimmer is an unknown quantity at this point
You should definitely invest in a Bentley Manual for the E30 - it's got detailed electrical wiring diagrams and good descriptions, pictures, diagnostic tests, etc. It costs ~$40, but if you're trying to do anything yourself, it's a must. Dont' get a Chilton or other brand...they're not as comprehensive.
I've done a bunch of work on my E30...some of it having to do with the fuel pumps (there are 2, an in-tank pump, and a main fuel pump). All the relays are in the relay box on teh driver's side under the hood...or just outside of the relay box.
Get the Bentley - it will answer 90% of your questions.
87bimmer is offline   Reply With Quote
Old 07-17-2004, 02:47 AM   #4 (permalink)
IrishBimmer is an unknown quantity at this point
Send a message via AIM to IrishBimmer
I would definitely check the relays, that's most likely the problem... The car wasn't jerky while driving it though was it? Because my fuel pump went out a while ago and before my car completely died, i would lose power for a few seconds and then it would just come back on, which made a not so nice ride... so ask your dad about that.
<img src='http://memimage.cardomain.com/member_images/5/web/401000-401999/401400_23.jpg' border='0' alt='user posted image' />
IrishBimmer is offline   Reply With Quote
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
Fuel Pump BMW for life 5-Series (E12,E28, E34, E39, E60) 2 02-25-2005 05:03 PM
Fuel Pump Location Biernacki 3-Series (E36) 3 02-16-2005 02:59 PM
Fuel Pump Location Biernacki 3-Series (E46, E90) 2 02-16-2005 01:57 PM
