Fuel Pump - BMW Forum - BimmerWerkz.com
Old 05-05-2005, 05:23 PM   #1 (permalink)
codog7518 is an unknown quantity at this point
I have a 1987 bmw 325is. The car can go fine for a week or even a month and then all of sudden can just cut off and want cut back for a while. Sometimes the car doesnt crank back up at all. I just need to see what my causing this, it runs fine, then it just quits. Thanx.
codog7518 is offline   Reply With Quote
Old 05-05-2005, 05:42 PM   #2 (permalink)
BimmerKris's Avatar
BimmerKris is an unknown quantity at this point
by not crank, do you mean turn over, or does it turn over and not start. it it just stalls and takes a bit to start up again, chances are it's your in tank fuel pump. mine did the same thing. you have to remover the back seat and on the passenger side you'll see a cover that is bolted down. that is where it is and should hopfully be you problem.
<img src='http://bmwforums.penguinstudios.com/BimmerKris/salesig%20copy.jpg' border='0' alt='user posted image' />
<a href='http://www.acantha.ca' target='_blank'>www.acantha.ca</a> 100% thrash your face off metal
BimmerKris is offline   Reply With Quote
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
Fuel Pump BMW for life 5-Series (E12,E28, E34, E39, E60) 2 02-25-2005 05:03 PM
Fuel Pump Location Biernacki 3-Series (E36) 3 02-16-2005 02:59 PM
