Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 08-16-2007, 06:16 PM   #1 (permalink)
Photos: 0
shopkeep is on a distinguished road
fuel pressure
how should I go about increasing it? just thought id ask here before i dive into the rest of the internet.
This is for an S52 swap btw.
shopkeep is offline   Reply With Quote
Old 08-16-2007, 07:52 PM   #2 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Photos: 5
What year and model is your car now? If you have a late production E30 you don't have to do anything to the fuel system, just run the stock regulator on the S52 and it will be fine.
My M50 Powered E30 Page
Old 08-17-2007, 12:46 AM   #3 (permalink)
Photos: 0
It's a 91 318is
Old 08-17-2007, 01:11 PM   #4 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Photos: 5
Looks like the M42 uses a 3.0 BAR system so you will probably be ok with the pump that is in the car. You should be able to be buy the fuel pump itself separate for a E36 and with a little tweaking it will fit in a late E30 pump bracket if you wanted to go all the way and use an E36 3.5 BAR pump. I ran my M50 for months on the stock 3.0 BAR pump and noticed no difference when I went to the 3.5 BAR pump. I lucked out and got the pump for free otherwise I wouldn't of bothered with swaping in the different pump.
Old 08-17-2007, 10:23 PM   #5 (permalink)
Photos: 0
ah, ok thanks, i was hoping i wouldnt have to get a new pump. yay.
Old 10-04-2007, 06:11 PM   #6 (permalink)
Car: 320i 1985
Photos: 0
taz131 is on a distinguished road
I got a 85 320I and some time ago I'd problems with the pressure regulator on the return to the tank.So at the time i saw some valves you could regulate them to your needs.
Before I change the faulty one to a new ,it I'd put a meter on the gas line ,usually got around 3psi ,but when the valve blocked i?d got 7psi and forgetting fuel consumption the car then use to "fly"
taz131 is offline   Reply With Quote
Old 10-04-2007, 07:56 PM   #7 (permalink)
BMWJNKY's Avatar
Car: '89 E30 w/M50
Photos: 5
Is your car carburated? Because in an E30 with an M20B25 or M42B18 the fuel system should run around 3-3.5 bar max which is about 44psi, and be in the 1-1.5 bar range at idle.
vB code is On
88 325i, what's the fuel pressure? and other ??s draculia 3-Series (E21, E30) 1 08-28-2004 02:32 PM
Cold Start Problem (fuel Pressure Drop) BEX 3-Series (E36) 6 05-16-2004 08:35 PM
320i in-tank fuel pump? nightsurfride 3-Series (E21, E30) 1 01-28-2004 11:45 PM
How to test fuel system pressure? babzenuda 3-Series (E21, E30) 4 01-13-2004 05:35 AM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
