Fuel issues? Car bogging! - BMW Forum - BimmerWerkz.com
Old 09-26-2005, 02:08 PM   #1 (permalink)
ReaverJam is on a distinguished road
Hi guys,
I am having a problem to which i am searching for a solution. I started up my car last week and it tok forever to start, when it did however it started off as if it was grumbling. It grumbled for a bit and i gave it some gas, after a couple seconds of keeping it at aroun 3500rpm, the car smoothed out. it happened again this morning. Another issue that may be related is that i cannot rev cleanly and swiflty from idle. For instance, you know the old "youngster driver" vibe revving, i can't do it. The moment i try that the car bogs and tries to stall, recovering only when i either come off the throttle for a while or give it a steady rev.
Can any of u guys shed light on the topic?
My theories:-
Fuel pressure issues
  1. Fuel pressure issues
  2. Vacuum leak (somewhere)
  3. Clogged Injectors???
  4. Throttle position switch.
All answers will be appreciated.
Thanks.
ReaverJam is offline   Reply With Quote
Old 10-02-2005, 07:46 AM   #2 (permalink)
You may have a fuel-pressure problem first thing I’d do is have a good look for leaks old fuel hose cracks with the engine at idle check the whole fuel system from cold to hot
Old 10-02-2005, 10:16 PM   #3 (permalink)
gsrboy171 is an unknown quantity at this point
or air flow meter. does you car gives off codes??
<span style='font-size:14pt;line-height:100%'>NYC WHAT'S UP!!!</span>
gsrboy171 is offline   Reply With Quote
Old 10-02-2005, 10:26 PM   #4 (permalink)
Old 10-03-2005, 09:40 AM   #5 (permalink)
No. There are no trouble codes in the system.
Old 10-04-2005, 10:16 PM   #6 (permalink)
guywithblack88e30's Avatar
guywithblack88e30 is an unknown quantity at this point
when was the last time it got a tune up? my car used to do the same till i cleaned out the idle control module, also try changin the fuel filter
Member of got its raining(in Members Lounge) to 100, 237, 250, &amp; 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
guywithblack88e30 is offline   Reply With Quote
Fuel Leak ajreich 3-Series (E36) 1 11-13-2005 08:00 AM
Fuel Filter Issues dsstultz 3-Series (E21, E30) 6 04-12-2005 11:07 AM
Broken Idle Control, Fuel Pumps And Afm Issues ronpapworth 3-Series (E21, E30) 1 04-05-2005 11:36 PM
(e28) Fuel Door Seized And Ignition Issues californiarocker 5-Series (E12,E28, E34, E39, E60) 2 01-21-2005 12:59 PM
