| Fuel Gauge Wire No reponses (yet) to my IC wiring post, so I was wondering if their is a separate wire to the IP fule gauge. I have had troubles with readings and suspected it was a bad sending unit, as with a full tank all is well and when I get to 1/2 tank or below there is no correlation between level and actual fuel in tank. Currently I see no reading at the gauge (it was at reserve indicated when I pulled the cluster).
1990 325ic |
