If I read you correct, the car is full of gas it is the gauge that does not work. Sounds as if the fuel level sending unit is shot, if the 320 is like the 325, the sending unit is under the rear seat cushion, passenger side.
Yeah probably just the sender going south. You can disconnect the plug from the sender and short the two wires together in the plug and turn the ignition key on and the gauge should go to FULL. You remove the sender by removing those four nuts and pulling it straight up (depending on the model year it's probably mounted integral with the fuel pump housing...). If you wanted to remove the fuel pump you would just turn that remaining housing counterclockwise a quarter turn and pull it out too. But don't unless you really have to because you introduce somewhere else to leak. If it's an older 320i with the external fuel pump the sender is just mounted in the tank by itself. You didn't say what year yours was.
