Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 04-10-2005, 06:43 PM   #1 (permalink)
Photos: 0
dsstultz is an unknown quantity at this point
I need some help. Have an 83 320i, that i purchased a few months ago. I have been trying to do some preventative maintenance, such as a fuel filter replacement. I went to Schucks and ordered one. It came in yesterday, picked it up today and went to put it in. My Haynes manual says the filter is on the left side of the radiator..., so i removed the "filter" from that location, to find it did not look like the filter i purchased, or the filter shown in the haynes book. It also did not have the threaded connections, like the new one. It is large, has 2 nipples on one end, and a purolator label. However, back by the fuel tank, there appears to be a filter that looks exactly like the one in the book, which does have the threaded connections. Is the Hanynes book wrong? I kinda think so. If so, what is that thing in the fuel line up by the radiator? It sounds like it is a sand or charcoal filter, because the material inside is heavy and shakes around. There is no mention of it in my repair manual. Please help.
Thanks.
dsstultz is offline   Reply With Quote
Old 04-10-2005, 08:53 PM   #2 (permalink)
Idle Member
Photos: 0
joshh is an unknown quantity at this point
I always buy those kind of parts from an import shop that sells aftermarket BMW parts. Sounds like the wrong filter???!!!
Finally pulled the M50 from the donor car.
joshh is offline   Reply With Quote
Old 04-11-2005, 03:32 PM   #3 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
Photos: 5
I think you've got it right. That can up by the radiator is probably the charcoal canister. In my '85 325es, the fuel filter was on the drivers side near the fire wall, and there was no mistaking it, because about 4 gallons of gas came out of it. (ok, not that much) I do think that the older E30's had the Fuel Filter in the back near the driver's rear wheel. I would think that Haynes would have that locked on for you. You should also get yourself a Bentley Manual. It's better to have 2 reference sources than 1. Good Luck!
My BMW Blog
Old 04-11-2005, 03:55 PM   #4 (permalink)
WoW killed my social life
nukeduster's Avatar
Car: 95 Daytona Violet M3
Photos: 0
[snapback]330176[/snapback]
I have both a chiltons and haynes for every car.
Haynes on more then one occasion has been flat out WRONG on some things although is sometimes more descriptive when they are right(which is 98% of the time). I hear good things of bentley so for my next car thats definately the one I am going to be buying.
On late e30's the fuel filter is under the car, under a black cover that is held on via 3 plastic nuts which is appx 2 feet fore of the drivers rear wheel. When replacing it, definately replace the fuel lines. They get cracked over time and I've had at least one e30 burst into flames from a brittle/cracked fuel line.
It went something like this...
driving up to my friend aarons house...
my friend aaron outside with a beer in his hand.
i step out and greet him.
he looks over my shoulder and asks casually "hey rich, is your car normally on fire?"
i blink and reply "why, no, no, its not usually on fire. why?"
calm as can be:"oh, because it is."
i turn around to see my lovely 325's engine compartment up in flames. was able to get it out, at the expense of losing all the gorilla hair off my right arm, and saved the engine, but lost some of the electronics and it killed the AFM.
lessons learned: when you replace the fuel filter, dont go cheap and not replace the fuel lines. they arent THAT hard to treplace, they arent very expensive, and they are CERTAINLY less expensive then the alternative.
When you fight, you don't fight for abstract values like the flag, or the nation, or democracy. You fight for your buddy. You fight to keep him alive, and he fights to keep you alive, and you go on that way, day after day, battle after battle. And when one of your buddies dies, something inside you dies as well. But you go on. You fight, so that his death isn't meaningless, his sacrifice isn't for nothing.
-Dick Marcinko
Old 04-11-2005, 06:50 PM   #5 (permalink)
Idle Member
Photos: 0
Good point and to add to that. Make sure you buy fuel injection line not just regular fuel line. And it is about $5.00 a foot. You wont need more than 7 feet of it for an E. I know you have an I.....
Old 04-12-2005, 06:27 AM   #6 (permalink)
Photos: 0
I agree with all that been said, especially about the rubber fuel hose. I would guess that on a car the age of you’re the fuel filter si mounted on the left inner wing below the inlet manifold, it was only the last E30's that had them under the back of the car, I think what you're looking at is the fuel pump there're very similar to look at but if it's got wires going to it it's the pump (be careful with petrol)
Old 04-12-2005, 12:07 PM   #7 (permalink)
DJProfessor's Avatar
Photos: 0
DJProfessor is an unknown quantity at this point
the fuel filter for the E21 is right up by the radiator if i am not mistaken, cause it is CIS and the CIS usually has the filter right by the fuel dizzy.......i will check my E21 this evening when she comes home to begin the motor swap
sexually assault a member of the VW community? if you belong to dubdojo or swov.org they will gladly circle their wagons and support you.
DJProfessor is offline   Reply With Quote
vB code is On
Do post-1994 E36 need fuel filter changed, ever? Delmarco 3-Series (E36) 13 08-24-2006 02:39 PM
Changing The Fuel Filter hocuzanden 3-Series (E36) 13 12-11-2004 09:45 PM
whisling sound at fuel filter javieruz 3-Series (E21, E30) 2 04-12-2004 11:17 PM
Fuel Filter Removal BEX 3-Series (E36) 3 03-17-2004 09:55 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
