Are there any Fuel filters out there that also work on the E30 but cheaper. I've seen a few FRAM ones that look very similar, but a fraction of the price since theyre made for some American cars...
And Replacing. It looks pretty straight forward, but don't want to crack the old loopy hoze, how can i clamp it without damaging the old hoze?
I'm not sure where you are shopping but a fuel filter for an E30 shouldn't be any more than $15-$20 and it only needs to be changed once a year or every 25K miles.
It looks like the first parts store I went to was a ripp. They were gonna charge $50, but I bought one for $20 today from another place.
So as far as replacing; I was looking at my old filter and it is much bigger than the new BOSCH 0 450 905 201 I got for my BMW. I don't think the last owner replaced it with the right filter.
Do I just slip the clamps down the hozes, tighten them, replace filter and then slip clamps up and tighten around filter nipples again?
The hoze coming from the tank to the filter looks really stiff and I'm afraid of cracking or breaking it if I clamp it shut. Am I being paranoid or should I just go ahead and do it??
if the hose looks brittle, then go to your local autoparts store and pick up some new hose. all you need is 1 ft of fuel injection hose. most likely they won't have 8mm inner diameter hose, so just get 5/16 id.
Originally posted by draculia@Sep 3 2004, 02:54 AM if the hose looks brittle, then go to your local autoparts store and pick up some new hose. all you need is 1 ft of fuel injection hose. most likely they won't have 8mm inner diameter hose, so just get 5/16 id.
what he said
__________________ Kyle Sutherland
1995 BMW 540i/6: The Calypso Beast Vid 0-70ish 1987 BMW 325es: Face & Butt Lifted/M50tu Swapped*Sold* 1985 VW Scirocco: Too many mods, money pit*Sold* E34 Plate Filler Wanted!
Don't worry about clamping down the hoses, at most not counting whats in the filter, a 1/4 cup will spill out. Some of the fuel hoses are a formed hose so it may look stiff but it is just shaped so it won't kink. Unless the hose feels rock hard and is showing signs of cracking it should be ok to reuse.
Originally posted by draculia@Sep 3 2004, 04:54 AM if the hose looks brittle, then go to your local autoparts store and pick up some new hose. all you need is 1 ft of fuel injection hose. most likely they won't have 8mm inner diameter hose, so just get 5/16 id.
I did it and it was no problem. Good thing too; the old one literally had crap driping out of it.
My BMW runs smoother and more efficient now. No more hesitation during acceleration.
Can I ask how hard it was to get to the part of the tank you needed to? My filter hasn't been replaced in the last year, and it's on the list of post-winter maintenance stuff.
Originally posted by Aether@Oct 4 2004, 03:22 PM Can I ask how hard it was to get to the part of the tank you needed to?* My filter hasn't been replaced in the last year, and it's on the list of post-winter maintenance stuff.
[snapback]204705[/snapback]
I bought the BOSCH filter from a parts place I use quite often for their really good price. ran me about $25.
It's called SELECT Auto Parts. Look the number up on www.canada411.ca I can't recall it now. But call ahead and have the guy order it.
As far as replacing it. The filter is outside and runs on the left rear side of the car. mine was right in front of the laft rear tire. It is really easy to replace. Just go grab a manual from the local library and follow the instructions if you're not sure. you basically take the fuel fuse out, start the car to choke. Take the gas cap off, clamp the hozez, take the old filter out (a bit of fuel will spill, be ready and don't panic). put new one in and reverse the process.
If youre really not comfortable playing around fuel, then just take to your mechanic. If you know him , he either won't charge you or maybe a few bucks. The whole thing takes like 5 minutes to do.
