friggin' oil filter won't come off... - BMW Forum - BimmerWerkz.com
Old 04-26-2007, 11:11 PM   #1 (permalink)
Festivus yes, bagels no..
yammahamma's Avatar
Car: '01 330i
yammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to beholdyammahamma is a splendid one to behold
Send a message via Yahoo to yammahamma
I am so sick of these blow jobs that run these stupid lube shops....
they cranked my oil filter on way too tight....and I've broken two filter wrenches trying to get it off....
now it's got a big whole in the side because the last wrench broke through, but still didn't budge the filter....
what should I do to get it off?
(I can't drive 'cause the filter has a big hole in it......and I can't take it back to the shop that changed it because they went out of business....)
please help
yammahamma is offline   Reply With Quote
Old 04-27-2007, 08:52 AM   #2 (permalink)
jfertita's Avatar
Car: 86 BMW 325
jfertita is on a distinguished road
What if you shoved a breaker bar through it and tried to unscrew it like tire iron style?
jfertita is offline   Reply With Quote
Old 04-27-2007, 09:05 AM   #3 (permalink)
Crazy Fabricatin' Admin
gotKRAUT's Avatar
Car: '87 325es M50tu Swapped
i have had to do this before when the oil filter wasnt changed on a car for 20,000 miles, never based on "over tightening" as if you over tighten it the rubber gasket just breaks!?
that being said, you may want to invest in a better oil filter remover something like this
if thats a no go then something like this
if thats a no go, something like this
but if none of those work you can take a little tiny screw driver and jam it into the where the gasket meets the housing and break the seal
next, replace your oil filter with a K&N one for one simple reason
the damn nutt welded to the top, makes life so much better
Kyle Sutherland
1995 BMW 540i/6:
The Calypso Beast Vid 0-70ish
E34 Plate Filler Wanted!
Old 04-27-2007, 09:51 AM   #4 (permalink)
Oil Filter
I use a rubber strap wrench that goes around the filter case and tightens up on itself as you turn the handle.
Old 04-27-2007, 10:18 AM   #5 (permalink)
yammahamma's Avatar
Car: '01 330i
Originally Posted by gotKRAUT
i have had to do this before when the oil filter wasnt changed on a car for 20,000 miles, never based on "over tightening" ...
the filter was changed 3,200 miles ago....
I broke two of these trying to get it off:
this is like the one that punched the hole in the side...I'm going to try with it again today...
a plasma cutter is starting to look like a better option...
I wish there were more room to use a beaker bar or something like that...
I think I'll try ramming a screwdriver through it (freak there's already a hole in one side) and try and use that for some leverage....
freeeeaaaaak.....
Old 04-27-2007, 07:20 PM   #6 (permalink)
yammahamma's Avatar
Car: '01 330i
yamma: 1
oil filter: 0
this is what it looked like when I got the mo fo off.....
waaaaaaaaaay too much work....
Old 04-27-2007, 09:04 PM   #7 (permalink)
Car: Opening soon:
You penn-soiled your motor? Dude, pennzoil and quaker state are the two of the worst motor oils ever. I have seen these 2 motor oils gunk the crap out more motors than I care to recount.... Castrol, havoline, valvoline, mobile, or mobile 1, or even better: Amsoil, are the oils to use.
Old 04-27-2007, 09:39 PM   #8 (permalink)
fastshivy's Avatar
Car: 1999 540i
fastshivy is on a distinguished road
Plus 1 ....Those 2 oils will leave 2 inches of crud in an engine....Plug up drain holes etc. etc. etc.
fastshivy is offline   Reply With Quote
Old 04-27-2007, 09:43 PM   #9 (permalink)
yammahamma's Avatar
Car: '01 330i
Yea, I remember you saying that before....
The reason pennzoil was in there was...I took my car to the most reputable lube shop here in town.....I didn't realize they use such bad oil....needless to say, I'm never going back there....
but I just filled her up with Mobile 1.....and that's what I'm stickin' with
Old 05-01-2007, 03:02 PM   #10 (permalink)
Rfitz25's Avatar
Rfitz25 is on a distinguished road
LOL
Dang thats funny.
Glad you got it off.
I use BMW, or MANN filter. $8 v $4
New Mobil 1, 15-50 $23 5qt at walmart
copper crush washers from stealership or autozone
Ive got slightly different wrench than pictured.
hard to get it on off, around the filter but it works.
I think your only supposed to go 1/8-1/4 of a turn after the gasket hits the block.
Some shops go too tight, they will also screw up/strip the fill plug threads without using new crush washer. I reuse it a few times then replace.
Good luck.
Cheers,
Richard Fitz
'87 325is Delphin Metalic
Rfitz25 is offline   Reply With Quote
Old 05-01-2007, 03:12 PM   #11 (permalink)
yammahamma's Avatar
Car: '01 330i
This has already happened to me....they stripped the pan....(no on believes me when I say they stripped the pan and not the plug......but believe me, they stripped the pan....) I stopped going to that shop too....not to mention they put the wrong oil in it AFTER I told what kind I wanted, and they stripped the hex dif plug too, and then lied to me and said they checked the dif fluid....neither me, or anywhere else could get the dif plug out.....I had to replace the dif cover.......booo
no more lube shops for me
Old 05-01-2007, 04:05 PM   #12 (permalink)
Teh Peetsa Gai
ldsbeaker's Avatar
Car: '86 325es, '87 535is
srsly. no lube shops period.
No one cares about your car like you do.
I don't even like leaving my car at the shop to mount new tires or get an alignment... (the only stuff I can't do)
My BMW Blog
Old 05-01-2007, 04:11 PM   #13 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 84 325e
wo i've never seen a filter that mangled before.
Old 05-01-2007, 04:13 PM   #14 (permalink)
teh Canuck....eh
PhatCat's Avatar
Car: '86 E30, baby! '05 Legacy 2.5GT Ltd
PhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond reputePhatCat has a reputation beyond repute
Send a message via MSN to PhatCat
Shit yamma, you should let a dozen eggs bake in the sun for a week and then...DRIVE BY!
All great things are simple, and many can be expressed in single words: freedom, justice, honor, duty, mercy, hope.
Sir Winston Churchill
PhatCat is offline   Reply With Quote
Old 05-01-2007, 04:17 PM   #15 (permalink)
gotKRAUT's Avatar
ya i have seen engines inside turn yellow from the amount of wax left behind from penzoil...more wax waxoil lol
but ya i have had filters stuck on like this, it sucks, thats the way the E30 was when i got it...
Kyle Sutherland
1995 BMW 540i/6:
Changing Oil Filter Housing Gasket and O-Ring Live_the_Curves 3-Series (E36) 8 04-25-2010 01:34 PM
oil leaking from a few places... yammahamma 3-Series (E21, E30) 31 11-02-2006 10:28 PM
Oil additives and the damage they do. Starmavin 3-Series (E21, E30) 2 05-18-2006 01:49 AM
Spin-Flow Filter luvinangel Bimmer Talk/Motorsports Talk 6 07-07-2004 05:22 AM
