| i would just buy a used or refurbished one which will run you about $40. it would cost about $30 to buy a new gear which is most likely the problem. That happened to my odometer around 128k miles and after i bought a used speedo and a new SI board i took my old one apart and found 3 bad gears. It seemed like the grease behind the gauge absorbed into the gears and caused them to easily fall apart |
