Fast Blinking Right Hand Turn Signal - BMW Forum - BimmerWerkz.com
Old 01-18-2005, 03:07 PM   #1 (permalink)
BMWDriver86 is an unknown quantity at this point
I was driving my bmw today and I noticed that the right hand turn signal blinks really fast on the turn signal, but the left works normally, I looked at the the tail light and it was blinkin fast. Any ideas on what this might be? Get back to me please.
BMWDriver86 is offline   Reply With Quote
Old 01-18-2005, 03:12 PM   #2 (permalink)
Kowalski's Avatar
did you just buy it? cause the guy berfore you could'v got a heavy duty blinker put in, they have different speeds, and he just might have gotten you one of them, or replace your relays other hten that i have no idea.
264* roatation and 388 lift
Old 01-18-2005, 03:13 PM   #3 (permalink)
Kowalski's Avatar
mine also does that some times too, not sure why but im going to replace the relay cause im pretty sure it never has been replaced. it does it some times and then it stops some times im nto really sure what the deal is.
Old 01-18-2005, 04:45 PM   #4 (permalink)
BMW@JMU's Avatar
BMW@JMU is an unknown quantity at this point
Try checking the front turn signal also. Chances are that bulb is out or not completing the circuit. If it is the front one, try giving the lense a bump with your hand...that may do the trick.
-1985 325e - 5000 RPM's of Fury
BMW@JMU is offline   Reply With Quote
Old 01-18-2005, 08:51 PM   #5 (permalink)
yea I did that and it worked, my only other problem is starting the car when its cold, it was just in the shop for no spark and fuel, they traced the problem to the power distribution box and repaired electrical open at power distribution box. When I got it out it was doing fine and I just got it out of the shop on the 11th of january. Any ideas what the problem could be now. it keeps trying to start till the power drains out and from there it will start like 4 mins later after u jump the car. The battery is brand new.
Old 01-18-2005, 09:10 PM   #6 (permalink)
Kowalski's Avatar
[snapback]274446[/snapback]
could be your idle control valve, on my car its on the back and its a vacume valve thats controlled by the computer, it should make a click noise when the car is turned on or you can take it out and hook it up to your battery with 2 wires and it should flip open, if it doesn't its broken. you can get one at a pick apart for like 10-20 bucks. thats what im thinking off the top of my head, other then that, could be the fuel pump, and its taking forever to get up the fuel presure so it can actualy inject into the engine and it takes that long to do so. ill keep thinking and let ya know what it could be if anything else pops into mind
Old 01-19-2005, 05:51 PM   #7 (permalink)
BMW@JMU's Avatar
And it runs after you jump it? How long does it take for the batter to go dead? I can't help you too much right now, but I'll look it up in my Bentley once I go home on Friday to get my car out of the shop. I can finally drive it after two weeks.
Old 01-19-2005, 06:21 PM   #8 (permalink)
[snapback]274199[/snapback]
Old 01-19-2005, 06:24 PM   #9 (permalink)
How is the front parking light, does it work? These are dual filament bulbs (one filament for parking and one for turn) and on my Bimmer I had a wire broken for the parking light and though the turn signal worked, the parking light did not and I had a rapid turn signal on that side.
Old 01-21-2005, 01:12 PM   #10 (permalink)
All wheels rolling is an unknown quantity at this point
Sounds a lot like a problem that I had too. Not starting and ends up draining the batery. Check the COLD CRANKING AMPS of your battery. BMW's of this era required 650 Cranking amps which would mena that you would need at least 725 CCA's to get it going in the winter. I thought that my problem was worse but I got a new battery that has 985 CCA's and it starts like it's 1989 right now (aka brand new). I'd suggest that.
Preston
All wheels rolling is offline   Reply With Quote
Old 01-21-2005, 11:48 PM   #11 (permalink)
yes, the turn signal thing worked, it blinks normal now. But I dont know I got a 700 cca battery, got it from advanced auto parts, and last night I tried to start it and wouldnt start. it was really cold out and I jumped it with my other car and that did not work and then I noticed smoke comming from the tail pipe, then under the car, and then from the hood. I dont know if thats bad or what happend, but I didnt get it started that night.
Turn Signal Problem, stuck on, not blinking. jek1955 3-Series (E36) 2 10-27-2005 06:48 AM
How To Make Fast Turn Signal Blinkers... diehard_vue 5-Series (E12,E28, E34, E39, E60) 18 04-18-2005 02:58 PM
1984 528e Turn Signal Questions. rock_martyr 5-Series (E12,E28, E34, E39, E60) 1 11-09-2004 11:47 PM
Turn signal problems beau 3-Series (E46, E90) 3 08-22-2004 09:22 PM
