Ok.. its not all that easy.. but its doable...
In order for you to do this.. you will have to take the fan out.... which means it has to be disconnected from the pulley that drives the water pump...
You do not need to remove the fan shroud to replace the fan clutch.....
If you look striaght down you should see the shaft that goes into the pulley infront of the water pump.. well on that shaft it should look like a hexigonal nut. well it is...
There is a special tool for this procedure (fan removal tool).. it holds the pulley infront of the water pump still.. while you torque the bolt .. (COUNTER CLOCK WISE)... to remove the fan. It looks like this...
http://www.pelicanparts.com/BMW/techarticl...ement/pic11.jpg
It is possible for you to get that bolt lose but its not easy. I've found the best way to do it is.. take a medium sized flat head screw driver.. and hold it against one of the four nuts that hold the pulley on... and then insert the 32mm wrench (it might be rather hard to fit it in there with the four pulley bolts.. but if you play with it enough it will fit around the bolt) Then you turn the wrench counterclockwise.. and hold the pulley still with the flat head screw driver.
Once this bolt is disconneted... you should be able to pull the entire fan out between the shroud and the engine.
The clutch removal should be rather easy and self explanitory once you view it on the fan. Good luck! If you have any other questions.. PM me.
