Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
» Sponsor Links
»Garage Storage and Cabinets
Old 05-28-2007, 01:05 PM   #1 (permalink)
Photos: 0
R_Atkinson is on a distinguished road
Excessive Rear Tire Wear
The rear tires on my 86 325 are incredibly worn on the inside. I believe this to an alignment problem, but I don't know how to realign the rear end. Can anyone help?
R_Atkinson is offline   Reply With Quote
Old 05-28-2007, 03:02 PM   #2 (permalink)
bimmerguy82's Avatar
Car: 2004 ZHP
Photos: 0
take it to a shop that does alignments, ie: Les Schwab or something and they can do it.
BMWcrazy
Originally Posted by RoadsterMadness
As my race shop likes to say - "have your fun with the Asians and the Italians, but you MARRY a GERMAN!".
BMWCCA member#407674
Founding member of the hit 145 mph in my almost stock BMW club.
Old 05-28-2007, 04:38 PM   #3 (permalink)
Big Pimpin'
SpeedInfusion's Avatar
Car: ///M3,Corolla
Photos: 0
could be ur RTABs
Old 05-28-2007, 06:47 PM   #4 (permalink)
Fixie Ridin Administrator
gotKRAUT's Avatar
Car: 1987 325es
Photos: 0
rear alignment is non adjustable, they cant do anything
it has to be bent suspension components or bad bushings, most likely bad bushings
on second thought is it lowered? if so the rear camber is increased...just turn faster and it will wear even
Kyle
"PirateKrautFixieRidinEuroDestroyingRestoring BeerWineScotchRumDrinkingLovingMarriedMan"
M50TU TREEHOUSE HID LSD KONI BILSTEIN OZ IE ROGUE HELLA MAGNAFLOW MOMO DINAN CORBEAU K&N BLAUPUNKT
gotKRAUT's M50tu Build/Swap Thread *Updated on Thursday 10/09/08*
CarDomain Page
Old 05-28-2007, 08:35 PM   #5 (permalink)
Photos: 0
It isn't lowered. If it's not alignment, is the camber adjustable? If so, how do I do it?
Old 05-29-2007, 02:22 AM   #6 (permalink)
Car: Opening soon:
Photos: 0
It was said before, the rear is non-adjustable in any direction. Your rear bushings are shot.
You have two options:
#1 Replace the stock bushings (this is a good fix so long as the rest of the rear is in good shape, also the cheaper route)
#2 Replace the bushings with adjustable aftermarket bushings (although a bit more expensive, it will allow the rear to be fully adjustable, the best for stock or lowered cars)
P.S. E30's use an alignment technique called KDS and has special alignment requirements that must be met (weights have to be placed in your car, 100lbs drivers side, 100lbs passenger side some in the back and in the trunk with a full tank) to properly align the car. If not done correctly your car will handle differently and can eat tires up. I have done it both ways (with and with out weights, and the car defiantly handles better using the weights.)
Old 05-29-2007, 02:44 AM   #7 (permalink)
gotKRAUT's Avatar
Car: 1987 325es
Photos: 0
starmavin summed it up for ya
Kyle
CarDomain Page
Old 05-29-2007, 02:21 PM   #8 (permalink)
Photos: 0
I dunno. My bushings aren't in too bad of shape, but the struts look like they're slightly crooked. The rubber on the bushings is completely intact. Would the struts cause this?
Old 05-29-2007, 03:22 PM   #9 (permalink)
Car: 2004 ZHP
Photos: 0
Kraut is this true only for e30s? i've had my e36 have a 4 way alignment before. i've watched them loosen and adjust the rear.
BMWcrazy
Old 05-29-2007, 03:41 PM   #10 (permalink)
Rfitz25's Avatar
Photos: 0
Rfitz25 is on a distinguished road
MIne was wearing inside of rear tires slightly more than outside one side slightly more than the other.
It seemed to get worse the more they wore down.
It was because it was lowered and has more camber.
I put new tires on and they seem to be wearing evenly so far.
Of course I took Krauts advice and drive harder now. LOL
My rear mounts were shot too when I got the car a year ago and I replaced them ASAP.
Eyball your camber from the rear. You should be able to see it, compare to front. Are they straight up or leaned inward. Are they about the same left compared to right?
It may be toe in from something else being out of wack.
You can measure the distance from one side to the other as high up and as close to center as possible compare distance between front of tires and rear of tires. I think if they are toed out they wear on inside likr the front tires can. There are OEM offset bushings to correct this too. There are also OEM spring pads to adjust ride height whgich can correct camber issues.
But I'm just a garage hack most of this Ive read or heard from the pros like starmavin. Listen to him he rules!
Cheers,
Richard Fitz
'87 325is Delphin Metalic
Rfitz25 is offline   Reply With Quote
Old 05-29-2007, 05:15 PM   #11 (permalink)
gotKRAUT's Avatar
Car: 1987 325es
Photos: 0
ya E30 only...im almost positive you either bent something in the suspension of your subframe / rear trailing arm bushings are shot if the tire wear is that bad...
the other thing is, BMW's run a decent amount of camber...for a reason...and if you dont push it in the turns now and again its going to wear on the inside...especially if you ever "burn out" or do donuts its wearing just on the inside...
and the driving harder thing works even with over -2* of camber my tires wear even im not saying to speed or break any laws, just pitch it through the turns a tad faster...thats all
Kyle
CarDomain Page
Old 05-30-2007, 12:32 AM   #12 (permalink)
Photos: 0
I'm going tomorrow in the back up car (My mom's 94 oldsmobile) to autozone to buy replacement bushings. I'm now quite sure this is the problem, but it just blows my mind that the bushings went out on both sides at the same time. Is this a common occurence? Maybe I just didn't notice. The car seemed to eat the last set of tires really fast towards the end there.
Old 05-30-2007, 03:29 AM   #13 (permalink)
gotKRAUT's Avatar
Car: 1987 325es
Photos: 0
they carry them at autozone? i have never thought to buy factory quality parts at the local autozone lol
hope it all works out
Kyle
CarDomain Page
Old 05-30-2007, 07:23 AM   #14 (permalink)
Car: Opening soon:
Photos: 0
How exactly do you plan to press the old bushings out and the new ones in? Anybody that tired to change them on the ground with a hammer just ended up damaging the bushings and mauled up their control arms....
Old 05-30-2007, 09:17 AM   #15 (permalink)
Photos: 0
short of going to a shop, does anyone have any suggestions? Autozone does have a tool loan program for specialized tools such as this. I better check that first I guess.
vB code is On
Clinking noise / Tire wear problem KILOCHARLIE 3-Series (E36) 3 09-05-2006 11:42 AM
E46 Tire Wear clarkinc 3-Series (E46, E90) 18 03-25-2006 11:41 AM
1998 540i Rear Tire Wear Tom C 5-Series (E12,E28, E34, E39, E60) 7 11-12-2004 10:24 AM
Unbelievable rear tire wear cpadpl 3-Series (E46, E90) 3 06-28-2004 07:47 AM
Excessive tire wear BMWFourms4DCA 5-Series (E12,E28, E34, E39, E60) 7 06-13-2004 03:03 AM
SEO by vBSEO 3.1.0
