Excessive Camber On Rear Tires - BMW Forum - BimmerWerkz.com
Old 03-10-2005, 07:18 PM   #1 (permalink)
SteveO325is is an unknown quantity at this point
I had a feeling this much camber wasn't normal. I don't see any camber adjustments on the car, am I missing something or do I have to buy an aftermarket kit?
http://www.bmpdesign.com/product-exec/prod.../category_id/57
this may have answered my own question, but I'd still like to know if there is a stock adjustment? The camber is horrible, it's gotta be 2 degrees +
SteveO325is is offline   Reply With Quote
Old 03-10-2005, 07:27 PM   #2 (permalink)
"All this is done from within the engine compartment without raising the vehicle."
I'd love to know how this would adjust the rear camber...?
Old 03-10-2005, 08:26 PM   #3 (permalink)
well I keep on answering my own questions, they just copy and pasted.. so that was indeed for the front, it requires bushings for the back from my understanding. How difficult are these to install, if someone could just summarize how to do it, that would be great... I just want to see if the average person (me) can pull off a job like that
Old 03-11-2005, 10:37 PM   #4 (permalink)
draculia is an unknown quantity at this point
you have a few options. you can install eccentric bushings, they're fixed so you'll need to know how much camber correction you need.
you can get a slotted mount kit for the trailing arms. this requires welding and some basic fabrication.
you can install adjustable eccentric bushings. this would be the easiest solution. bmwbushings.com has some
and no there is no stock adjustment for rear camber or toe
draculia is offline   Reply With Quote
Old 03-12-2005, 07:00 AM   #5 (permalink)
[snapback]309262[/snapback]
thanks, now if only someone had a diagram on the installation of these... (the adjustible eccentric bushings)
Old 03-12-2005, 11:18 AM   #6 (permalink)
ye12 is an unknown quantity at this point
Try this site. The modification is more than for the average guy, but I thought you may be interested.
http://e30m3performance.com/installs/installs-3/jl_sub/
ye12 is offline   Reply With Quote
Old 03-12-2005, 08:34 PM   #7 (permalink)
[snapback]309498[/snapback]
way past my level
Thanks for the link though
Old 03-13-2005, 03:12 AM   #8 (permalink)
its not an easy task to put them in. its hard because its a fairly big process to drop the trailing arms. once the arms are out you'll need to get the stockers pressed out, or devise a way to get them out yourself. the new ones should just pop right in, if you get the bmwbushings ones.
its such a pain in the ass that i'm waiting to do them till i get new subframe bushings, a new diff, and new wheel bearings. that way i can drop everything as one, and break it down off the car.
19 inch rear tires eclipsevrl 3-Series (E36) 25 06-07-2006 02:40 PM
Rear Camber bigred318 3-Series (E36) 5 12-07-2004 03:52 PM
New tires for 325i wazzubmr 3-Series (E46, E90) 2 08-10-2004 05:16 PM
Rear tires rubbing mole 3-Series (E36) 11 04-14-2004 12:47 AM
