Engine will not stay on....Can anyone help?? - BMW Forum - BimmerWerkz.com
Old 04-06-2004, 10:05 AM   #1 (permalink)
explore is an unknown quantity at this point
Thumbs up
HI, i'm new to this. My wife has '81 320i. For some reason lately whe we start the engine it will not stay on, unless you press accelerator all the way, and even than idle jumps up and down. When you put it in to the gear and try to drive it...it stalls. Friend of mine try to look and said that he can hear a vacuum leak noise in the engine compartment......
Does anyone know what the problem might be and where I should even look for the vacuum leak, if that what it is?
Any help will be much appreciated.
explore is offline   Reply With Quote
Old 04-06-2004, 10:33 AM   #2 (permalink)
Aether's Avatar
Car: 1992 Jetta GLI
Aether is an unknown quantity at this point
Send a message via AIM to Aether Send a message via MSN to Aether
If it's not the vacuum leak, which I guess you'd find in the vacuum hose, you may just need to clean your injectors / spark plugs or replace them.
Four Five Six - It's on.
Aether is offline   Reply With Quote
Old 04-06-2004, 11:12 AM   #3 (permalink)
'85 318i's Avatar
'85 318i is an unknown quantity at this point
Send a message via AIM to '85 318i
yep, vacuum leak or plugs/injectors. change the plugs anyway... it can do noithing but good.
No posers, hacks or sellouts allowed.
"Only posers die..." - Stevo "SLC Punk!"
'85 318i is offline   Reply With Quote
Old 04-06-2004, 11:46 AM   #4 (permalink)
ok, where do I look for a vacuum leak..... I don't know anything about BMW engines. I removed the air filter assembly so it's out of the way. But how do I go about finding where the vacuum leak is? What am I looking for?
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-10-2006 11:56 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
