Engine Sputtering An Dying (mass Air Flow) - BMW Forum - BimmerWerkz.com
Old 06-21-2005, 02:50 PM   #1 (permalink)
moetinger is an unknown quantity at this point
Mechanic says my Mass air flow sensor/unit is bad and wants 700 to fix. Is this something that I can replace easily and get the piece cheaply or should I just let him?
If so where should I get the part?
moetinger is offline   Reply With Quote
Old 06-21-2005, 02:56 PM   #2 (permalink)
I would go for a used one. I had a MAF issue with my 1988 750 and I bought a used ($90.00 I believe) MAF and solved the problem. My cr would not die, but go into limp mode and was gutless, used MAF solved the problem. Try Vines.com or Active.com to start, there are a lot of good used suppliers on the web. Oh, less tha 30 minutes to change her out.
Old 06-21-2005, 02:57 PM   #3 (permalink)
[snapback]355566[/snapback]
there's one one on ebay for 9$ right now! Should I buy it w/110K miles on it?
Old 06-25-2005, 04:00 PM   #4 (permalink)
Kowalski's Avatar
Originally posted by moetinger+Jun 21 2005, 12:57 PM--><div class='quotetop'>QUOTE(moetinger @ Jun 21 2005, 12:57 PM)</div><div class='quotemain'><!--QuoteBegin-moetinger@Jun 21 2005, 01:50 PM
Mechanic says my Mass air flow sensor/unit is bad and wants 700 to fix.* Is this something that I can replace easily and get the piece cheaply or should I just let him?
[snapback]355573[/snapback]
[/b][/quote]
yes as long as it works and its the right one for your car, takes like 10 min to change it, do it.
264* roatation and 388 lift
Old 06-25-2005, 08:55 PM   #5 (permalink)
egk2 is an unknown quantity at this point
This would be a good opportunity to upgrade to the M30 AFM from
a 735i/635i/535i, get one with bosch# 027 on it.
2.8L M20 Stroker
egk2 is offline   Reply With Quote
Old 06-25-2005, 09:02 PM   #6 (permalink)
offabroadway is an unknown quantity at this point
If you guys don't mind the question, is Limp Mode present on a 325e?
<img src='http://www3.telus.net/drewdlespace/bmw/banner.jpg' border='0' alt='user posted image' />
Changed the car's name, now it's - Roxanne -1985 325e
offabroadway is offline   Reply With Quote
Old 06-28-2005, 06:13 PM   #7 (permalink)
[snapback]357064[/snapback]
I ended up getting (before I got this message) a sensor off ebayfor 20 including shipping. Guy said it works fine so I guess I'll drive it until it dies again then upgrade like you said.
Thanks for the advice. I really appreciate it.
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Engine Sputtering, Checked Alredy.. victorgallas 3-Series (E36) 0 02-24-2005 11:27 AM
