Engine Removal - BMW Forum - BimmerWerkz.com
post #1 of 9 (permalink) Old 03-31-2005, 08:12 PM Thread Starter
htp.bmw is an unknown quantity at this point
Send a message via MSN to htp.bmw
Hi.
So now that im removing my engine to replace it... I Have a few questions...
1. Is there an easy way to get the exhaust bolts off (all 6)
2. should I remove the transmission with the engine if so, is there a way to just remove the engine without taking out the tranny with it.
thanks for the help
-Casey
<span style='color:blue'>Proud Member of the Top Down Club</span>
<img src='
.:.HTP.:.
htp.bmw is offline
post #2 of 9 (permalink) Old 03-31-2005, 08:14 PM
Kowalski's Avatar
Originally posted by htp.bmw@Mar 31 2005, 06:12 PM
Hi.
thanks for the help
-Casey
[snapback]322490[/snapback]
it would be easier to take out with the tranny especialy if your taking it out anywys. there is torqx bolts on the belhousing you cna take those out if you want to remove the tranny b4 pulling, id do it with the tranny that way instalations is easier, put it up on jackstands (the front) that will make removal easier, and the exaust bolts just come off easy, shouldn't have any problem with those, maybe some liquid wrench or similar product.
264* roatation and 388 lift
Kowalski is offline
post #3 of 9 (permalink) Old 03-31-2005, 08:18 PM Thread Starter
Originally posted by Kowalski+Mar 31 2005, 05:14 PM--><div class='quotetop'>QUOTE(Kowalski @ Mar 31 2005, 05:14 PM)</div><div class='quotemain'><!--QuoteBegin-htp.bmw@Mar 31 2005, 06:12 PM
Hi.
thanks for the help
-Casey
[snapback]322491[/snapback]
[/b][/quote]
thanks for responding so fast...
here is the problem the exaust bolts are rusted on, we have already broken a few sockets on them *craftsmen tools* replaced for free. what do you recommend to do now
im gonna go get some liquid wrench any other ideas
the problem is we cant get to the 3rd bolt on the back of the exhaust pipes any tips?
-Casey
<img src='
.:.HTP.:.
htp.bmw is offline
post #4 of 9 (permalink) Old 03-31-2005, 08:52 PM
3serbmdubya is an unknown quantity at this point
if you are working at a shop, or maybe even in your garage and know what you are doing, try this.
1. get a torch and heat up each bolt till its pretty much red hot. (do this one at a time)
2. and then as soon as it gets hot enough. pour some cold water on it immediately.
3. grab a nice pair or vice grips (if you've sheared the bolt) and it should come off very easily.
i have done this many times with a cheap 20 dollar torch kit from home depot.
your other alternative is to weld a nut onto the bolt and then use a big breaker bar and impact socket. which are like chrome vanadium or something like that.
good luck
<img src='http://img73.exs.cx/img73/8618/post-4-1069548360.jpg' border='0' alt='user posted image' />
3serbmdubya is offline
post #5 of 9 (permalink) Old 04-01-2005, 12:43 PM
german-speed-demon's Avatar
german-speed-demon has a brilliant future german-speed-demon has a brilliant future german-speed-demon has a brilliant future german-speed-demon has a brilliant future german-speed-demon has a brilliant future german-speed-demon has a brilliant future german-speed-demon has a brilliant future german-speed-demon has a brilliant future german-speed-demon has a brilliant future german-speed-demon has a brilliant future german-speed-demon has a brilliant future
also if absolutely necessarry, drill out the old bolt, tap and thread it and replace with a larger bolt.
R.I.P fast 6
german-speed-demon is offline
post #6 of 9 (permalink) Old 04-01-2005, 09:26 PM
Kowalski's Avatar
which size drive arew you using i have craft. pro too and mine were rusted on and put a pipe on the end of the 1/2inch drive and cranked her off.
Originally posted by htp.bmw+Mar 31 2005, 06:18 PM--><div class='quotetop'>QUOTE(htp.bmw @ Mar 31 2005, 06:18 PM)</div><div class='quotemain'>
Hi.
thanks for the help
-Casey
-Casey
[snapback]322494[/snapback]
[/b][/quote]
Kowalski is offline
post #7 of 9 (permalink) Old 04-03-2005, 04:05 PM Thread Starter
alright so I got the exhaust bolts off, now I would like to know if I should remove the transmission with the engine or is it possible to just swap the engine?
thanks for your help
-Casey
<img src='
.:.HTP.:.
htp.bmw is offline
post #8 of 9 (permalink) Old 04-04-2005, 02:48 PM
Kowalski's Avatar
-Casey
[snapback]324560[/snapback]
you can but mating them in the car is a pain in the ass, i didn't take it out when i did my engine swap but it might be easier to mate them outside of the car... its all on your opinion. its also easier to reach the bellhousing bolts out of the car. but put the front on jack stands to get you more room to play with.
Kowalski is offline
post #9 of 9 (permalink) Old 04-05-2005, 10:50 AM Thread Starter
Alright... last night I got the engine out of the car it took me and 3 friends but its finally out. now I have 2 engines sitting in my garage on engine stands. now im just have to figure out what to do with the old one, maybe fix it or sell it.
anyway
thanks for your help... Casey
<img src='
.:.HTP.:.
htp.bmw is offline
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-11-2006 12:56 AM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 10:25 PM
BMW P83 Engine triggrhaapi Bimmer Talk/Motorsports Talk 0 07-21-2003 03:03 PM
