I drive about 35 miles to work every day. It's mostly Highway driving and I usually just set the cruise controll for like 70 to 75 mph. The last couple days when I get about 20 miles down the road the check engine light starts blinking on and off? As soon as I get below 60 it goes away. used I just got her back from getting a new transmission..could he have not put a sensor in correctly maybe. My oil and coolant levels are fine. I gotta get that timing belt changed though. I don't know when it was last done.
Thanks for any ideas..
__________________ 91 BMW 325 IX
BLACK
2 DOOR
5 SPEED
THE MORE RARE IT IS THE MORE IT COSTS TO FIX!
95 BMW 325 IS
GREEN
2 DOOR
5 SPEED
LET THE MODS BEGIN
I could be wrong but i believe the light usally has to do with air getting into engine it could be to much geting in engine or to little getting in engine
Member of got its raining(in Members Lounge) to 100, 237, 250, & 300 pages club...
Member of 3 Pedel club...
Member of ran away from cop using DRIFTING not speed(ok a little speed)...
Originally posted by guywithblack88e30@Apr 17 2005, 10:04 AM I could be wrong but i believe the light usally has to do with air getting into engine it could be to much geting in engine or to little getting in engine
[snapback]333849[/snapback]
okay..how do I fix that little problem.
BLACK
2 DOOR
5 SPEED
95 BMW 325 IS
GREEN
2 DOOR
5 SPEED
LET THE MODS BEGIN
The O2 sensor is probably going bad. If you don't know when it was last replaced replace it with a good BOSCH one. I'll warn you now though the BOSCH O2 sensors are $90-$110 but they only need to be replaced every 80,000-100,000 miles.
Originally posted by AJ's320i@Apr 17 2005, 12:45 PM The O2 sensor is probably going bad. If you don't know when it was last replaced replace it with a good BOSCH one. I'll warn you now though the BOSCH O2 sensors are $90-$110 but they only need to be replaced every 80,000-100,000 miles.
[snapback]333923[/snapback]
if your computer has self diagnostics do that before you buy the o2 sensor could be somthing simple just trigering the egnine light.
__________________ M42 Custom ground cams for sale PM me
264* roatation and 388 lift
Originally posted by Kowalski+Apr 17 2005, 03:55 PM--><div class='quotetop'>QUOTE(Kowalski @ Apr 17 2005, 03:55 PM)</div><div class='quotemain'><!--QuoteBegin-AJ's320i@Apr 17 2005, 12:45 PM The O2 sensor is probably going bad. If you don't know when it was last replaced replace it with a good BOSCH one. I'll warn you now though the BOSCH O2 sensors are $90-$110 but they only need to be replaced every 80,000-100,000 miles.
[snapback]334009[/snapback]
[/b][/quote]
90% of the time with the older DME's the trouble code will not be in the DME unless the Check Engine light is on all the time. Besides if he doesn't know the last time the O2 was replaced it should be replaced.
