Engine Cuts Out When Cold - BMW Forum - BimmerWerkz.com
Old 08-22-2005, 06:00 PM   #1 (permalink)
Majin's Avatar
Majin is an unknown quantity at this point
My 325i has been cutting out when the engine is cold and you start to push on the gas. I have replaced the plugs, wires, cap, rotor, fuel filter, has a clean k&n air filter. I have thought it could be the timing. The belt was replaced at 127k miles and its now at 204k. Is there any other things I should check on it?
Majin is offline   Reply With Quote
Old 08-23-2005, 02:04 PM   #2 (permalink)
77th Gear Member
325eXTATIC's Avatar
325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light325eXTATIC is a glorious beacon of light
Send a message via ICQ to 325eXTATIC Send a message via AIM to 325eXTATIC Send a message via MSN to 325eXTATIC Send a message via Yahoo to 325eXTATIC
[snapback]371675[/snapback]
Clogged Injectors? Crud built up on the back sides of the valves?
Do a search on this forum for "Hot Soak" and you will find several resources for this method of cleaning the injectors and valves. It helped my car a lot, although I was not having stalling issues, mine just hesitated and stuttered when I stepped on the gas, but the hot soak fixed it right up!
Hopefully this is all it will take for you to fix your car (it is fairly quick and CHEAP!)
Josh W.
Not currently on the Bimmer kick. Drivin' a 2003 Silver Civic at the moment, but I am STILL the Founding Member of the "325eXTATIC You're my hero" club.
Originally Posted by <b>superdeadman</b><br>Josh W. IS my hero!
325eXTATIC is offline   Reply With Quote
Old 08-23-2005, 02:36 PM   #3 (permalink)
Majin's Avatar
Ok thanks for the reply, I'll have to try it tomorrow when I have a day off and see how it runs after.
Help...92 318I Gas Engine Sounds Like a Diesel ? DougJP 3-Series (E36) 13 04-10-2006 11:56 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
