electrical of the backlighting and licence plate - BMW Forum - BimmerWerkz.com
Old 05-15-2004, 10:41 PM   #1 (permalink)
javieruz's Avatar
javieruz is an unknown quantity at this point
Send a message via ICQ to javieruz Send a message via MSN to javieruz
i have this problem: my backlighting for the dashboard doesnt work (the instrument cluster AND the backlight for the air controls) and the licence plate light and rear sidemarkers. all the fuses are all right and when i look into the fuse diagram i see tha one is for the left side and the other one is for the right side of the car and when i try to take them out the rear lights stop but rear sidemarkers on either side never work at all! so it probably means that the circuitry for the sidemarkers is probably on the same fuse but on a different circuit - along with the backlighting of the dashboard. can onyone confirm this or does anyone have am exact wiring diagram for this circuit???
once before i tried to play with the headlight 2-position switch and after some time all the lights started to work, they did for like 2 months and now they stopped working completely. i tried to check the switch and it seems to be working fine. it turns on the headlights and front sidemarkers but the none of the other ones i mentioned dont work. is there maybe some other fuse under the dashboard or anything else i can check? i know the electrical problems with e30 are very common but has anyone had this problem before???
thanks for any help!!!
<span style='font-size:13pt;line-height:100%'><span style='font-family:Arial'>'87 325i Convertible</span></span>
javieruz is offline   Reply With Quote
Old 05-19-2004, 02:59 AM   #2 (permalink)
heifetz17's Avatar
heifetz17 is an unknown quantity at this point
Send a message via MSN to heifetz17
The dash lights on my dad's Range Rover don't work either. The bulb is burned out. Unless Bimmers use some weird system for dash lights, you probably have a burned out bulb behind the cluster. Some cars have a bunch of bulbs behind the cluster, and some cars (our Rover) have fiber optics behind the cluster feeding off of one bulb. I don't know how Bimmers are. As for the sidemarkers, are the bulbs fresh or burned out? If they're fresh, take the whole sidemarker assembly out and follow its wiring. Make sure there are any:
*breaks in the wire
*the wire housing isn't worn away at any points (the wire will be grounding out on something)
*other shorts in the wire.
I had a wire that was inside a heat-case that looked fine. I cut the heat case in half to find that the wire was broken in half. I had to reconnect the wire to itself and reinsert into the heat-case. This might be similar to what's happening to you.
heifetz17 is offline   Reply With Quote
electrical of licence plate, rear side lights javieruz 3-Series (E21, E30) 1 03-14-2004 08:08 PM
