ecu code help - BMW Forum - BimmerWerkz.com
Old 03-24-2007, 11:26 AM   #1 (permalink)
photoguy30523's Avatar
photoguy30523 is on a distinguished road
ecu code help
i am gettting 1222 Lambda Control 1, why? what should i do to fix it? please help me.
photoguy30523 is offline   Reply With Quote
Old 03-24-2007, 11:05 PM   #2 (permalink)
Car: Opening soon:
1222 is stored when the DME detects excessive deviations in the air-fuel mixture (too rich or too lean) for longer than 10 seconds.
Possible causes: Faulty O2 sensor or bad contacts to O2, fuel tank ran empty or very low, injectors bad or clogged, incorrect fuel pressure (clogged fuel filter, bad regulator, faulty fuel pump), engine temperature sensor bad, intake or exhaust leak, fuel evap control bad or broken vac lines, air flow meter defective and/or the combustion is being messed up by mechanical failure (worn out spark plugs, low compression, intake/exhaust valves, bad plugs, wires, cap rotor, etc)
E30 Anti-theft Radio Code aaronhoy 3-Series (E21, E30) 4 06-08-2009 11:40 AM
Odd Radio Code Trouble 24valve 3-Series (E36) 5 11-25-2006 06:42 PM
How to enter the code of my car radio? nasko_bmw 3-Series (E36) 7 07-08-2006 08:16 PM
Asking For Code jshearer Audio and Electronics 1 12-18-2004 08:28 PM
stereo/radio anti-theft code xristo 3-Series (E21, E30) 3 03-02-2004 04:18 PM
