So I just recently found out that E30s have no built-in way to adjust the rear toe/camber
... and while i'm supposed ot have a slight amount of toe-in, i have quite a bit of toe-out. I know you can fix this with eccentric bushings from
http://www.bmwbushings.com/Rear%20Ca...20Bushings.htm http://www.bimmerworld.com/html/e30-...m-bushings.htm
and of course there are some from
www.bavauto.com
supposedly there are also KMac ones available, but i can't find a place to buy them.
The first two are adjustable and urethane, the bavauto ones are one-time press-ins (as far as i can tell) and are rubber.
Anyone running any of these- can you provide recommendations? I hear that the urethanes start squeaking after about 6 months and require periodic greasing.... how big of an issue is this? either of the above 2 urethanes better than the other? How easy is it to adjust the adjustable ones?
I think i may just go with the bavauto rubber non-adjustables to prevent noise problems....but i hope i get it right.
Any recs would be awesome.
