| Removing the old tweeters from the plastic triangle. If you manage to remove the triangular pieces without breaking them, you will discover the next challenge: removing the old tweeters.
The stock tweeters are glued in with some sort of epoxy that makes them really hard to remove.
here is what I did:
1. get some Goo Gone and spray it around the old tweeter. let sit for 15-20 minutes.
2. Grab some vise-grips and adjust them so they can grip the magnet
3. clamp on the the magnet and gently twist. You should hear a small cracking sound... it's just the epoxy giving up.
4. Once the glue starts to give up the tweeter should break free, but you might break the magnet in the process.. if this happens, just use the vise-grips to rip the other bits of junk out of the hole. |
