my car did this too! to this day i still dont know what it was. after 2 days it started and was like nothing happened!! ghead i still drove it to the bmw specialist though and told him what it did. he replaced the coolant temperature sensor, as that may have thrown out the cold start systems. its fine now and hasnt done it again. so yeah .....try leaving it for a couple of days without attempting to start. good luck! :wink
MY 89 325 IC HAS A VERY SIMILAR PROBLEM ONLY MINE HAPPENS WHEN THE ENGINE IS AT OPERATING TEMP AND IF I SHUT IT OFF AND LET IT SIT FOR 15 MIN OR SO IT STARTS FINE BUT WHEN I LEAVE THE DRIVE WAY IT SPUTTERS AND KICKS,IF I JAM THE THROTTLE AND CLEAR THE ENGINE IT RUNS FINE UNTIL THE NEXT TIME I TRY TO START IT HOT, IVE CHECKED ALL THE IGNITION COMPONENTS,FUEL PRESSURE IS GOOD, CLEANED ALL THE PRIMARY CONNECTORS,TESTED THE IDLE SWITCH,TESTED THE IDLE VALVE. I DONT KNOW IF ITS POSSIBLE BUT I THINK I,M GETTING AIR IN THE FUEL RAIL AND ONCE ITS SELF BLED ITS FINE. I,M TRYING TO FIND A LOCAL SHOP TO PURGE MY INJECTORS WITH CLEANER TO VERIFY THIS THEORY.
GOOD LUCK WITH YOURS. ARE YOU CERTAIN ITS BLUE SMOKE AND NOT BLACK FROM BEING TOO RICH
